My last build for 2025, Tamiya’s Tomcat inflight. OOB build with Furball decals. Unfortunately the canopy has a gap in closed position, so I had to add a plasticard shim to fix that. Otherwise a good kit. Happy New Year everyone ![]()
Beautiful Tomcat! Great job!
Hot damn! You did a astonishing job! That’s amazing!
I’m feeling the need. The need for speed.
Awesome work.
Well done all around. The exhaust effects and rings on the rods look great.
Thank you guys, much appreciated ![]()
Another stunner!!. Love the heat rings in the acrylic rod. Very nice touch ![]()
Great job and quite the dramatic display.
Great presentation, I will shamelessly copy yours when I build mine!
Did you try to use the Tamiya decals? I’m assuming they were too thick. I just picked up the 1/72 version and they looked maybe better than normal. I might see if furball has decals for the new Tamiya kit. Excellent work, the F14 looks amazing
I used Tamiya decals on the weapons, no problems. I used Furball decals on the aircraft as the set has all the stencil data, but if I built another one using the same set, I would use the Tamiya decals where required, yes they maybe a bit thicker than normal, but they still work.
Excellent way to show off all the stuff normally less-visible when sat on landing gear.
