Tamiya 1/35th scale T-34
Used Eduards engine screens otherwise oob,still gotta finish the crew thet are just sitting in there
7b.jpg[/IMG][/URL]
John
Might be good, might be terrible…can’t really tell anything from the pictures.
[dto:]
Ron
Sorry I don’t know how to make them bigger
John
The size is fine. You get to the larger pictures when you click on the ones here in the post. The problem is they are too blurry, out of focus and poorly lit to see the model.
Hi John,
One thing you may not be aware of. The towing rings on the front lip of the hull should not be there. They were added to the display tank Tamiya used as a reference when they designed the kit and of course, they were replicated.
I like it!
You have been informed about the towing hooks on the front. The cloth helmets were usually the same color as the the uniform (flat black a bit faded) and the end of the 76mm gun would not be silver but a black hole.
