I recently purchased a set of Fruilmodel tracks for my Trumpeter kit.
A friend told me(and after checking my kit,he is correct) the stock drive sprocket won’t work with the track set. Been checking a few sites(only 3,Sprue Brothers,Roll Models,Squadron), and haven’t found anything.
The issue is that the T-62 tracks you bought (ATL-01) were designed for the over scaled and ancient Tamiya kit. They fit that kit’s sprocket and not the more accurate Trumpeter kit’s sprocket. Depending on the actual T-62 version you have, there are several different tracks that could work.
I don’t pretend to be an expert, but I do know that the later kit T-62 model 72 uses the later ATL-11 tracks for the T-72. I was doing some cursory research for the Trumpeter IT-1 missile tank (based on the T-62) and was trying to figure out the proper tracks to get for it. I haven’t bought any yet because I wasn’t quite sure which ones to get.
But, when I last set a fruilmodel link next to the Trumpeter link, the teeth gap on the fruil part seemed to be set wider(space between the two rows of teeth on the drive gear,if looked at from direction of travel) than the Trumpeter’s spacing.
Thinking I may just need to add a spacer between the two halves.Gonna check that,plus any differences with the road wheels.
