T-34 suspension
Hey guys, I bought Jaguars t-34 moveable susbension set, and i dont get it. I want to put it on a T-34/85. Any help or is their another way to do it. [?][?]
You mean you don’t understand how to put it together? Are the instructions that came with the set unclear? I’m not familiar with that particular set, so I cannot offer “another way to do it.”
What seems to be the problem with it?
there are no instructions. Just peices. Also, is there another, better way to make moveable suspension with out buying aftermarket stuff?
Hmm…a lack of instructions could be a problem! Again, I’ve never seen the Jaguar set, and I don’t know which T-34/85 you’re building.
By moveable, do you mean fully operational (like for RC), or just positionable, like to conform to the ground in a diorama?
If you just want to position them, for the Dragon kits (and others with seperate suspension arms) it should be simple enough to just do whatever modifications are necessary on your kit to position the arms where you want them.
The Tamiya T-34s all have the suspensions arms molded on, I believe. In that case, you’d have to cut them off and replace them with something (or rework the arms you cut off), like the Jaguar set you have.
Hope some of this helps!
