SUGGESTION PLEASE
I HAVE A BEAUTIFIL 69 SHELBY IM WORKING ON I HAVE TO PAINT IT SILVER METALLIC I USE ACRYLIC TESTOR SPRAY CANS BUT I HAVE A HARD TIME GETTING THE FINISH I WANT ANY IDEAS ON WHAT I SHOULD DO FROM NOW ON SO I CAN BE PROUD OF MY WORK. ALSO SOME ONE SAID SOMETHING ABOUT FUTURE FLOOR POLISH TO BE USED AS A CLEAR COAT GLOSS EFFECT WILL THAT WORK ON OLDER MODELS IVE DONE TO SHINE THEM UP PLEASE GIVE ME SOME IDEAS SO I CAN PAINT LIKE A PRO
you can read this topic.
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=2488
for example.
And there more messages about this topic an the forum.
Deano, do you have an airbrush? If not, and you’re using spray cans, refer to the FSM article on spray painting with cans. Use a good quality paint, heat it thoroughly and carefully in a pan of warm water, and dust the color over your primed car body. After a couple of light dusting coats, hit it with a wet coat.
It never hurts to practice on a scrap car body if you have one, or try the technique on a tin can first. If you use a good quality gloss paint you wont need the Future clear coat. I usually use future to gloss up flat paints or as a clear sealing coat over decals, such as on an airliner.
Good luck.
