Su-27 blue colors
I need help somebody! I am trying to find out the blue camo colors for an Su-72 and everythhing I find has a different set of colors. So far, out of five tries, only one color has been the same, and in only three schemes. Does anyone know what the colors are or where I can find out? Thanks a million![:D]
Model master has several russian and flanker blues. Can’t say which are correct. I’m sure someone who knows will post.
Thanks plum1030!
I answered this one before for I think someone else so here is a copy of what I found.
Both Testors/Model Masters and Xtracolour makes a series of some blue paints in a Flanker Series. These might work if you want to do the common blue scheme also try these links.
Russian aviation page:
http://216.110.156.31/su27cm.htm
Flanker Kit Survey
http://www.flankerman.fsnet.co.uk/su27surv.htm
Found a kit review that used FS equivalents:- Light Blue FS 35550, Medium Blue FS 35450 and Blue/Grey FS 35526.
In Testors/Model Masters you have three colors:
Nº 2130 Flanker Pale Blue (SG)
Nº 2131 Flanker Medium Blue (SG)
Nº 2132 Flanker Blue/Gray (SG)… these are the appropiate if you want your Su-27 Flanker or Sea Fanker with original colors…
