reggie
I’m afraid that you may be screwed. Laquer is a lot “hotter” than enamels or acrylics and really “bites” in to a styrene surface (read - melts slighty). For years, Floquil Model Railroad paints were a laquer and every modeler I know (myself included) destroyed a plastic model if applied with a brush (unless you applied a protective coating which filled any detail). Then it was discovered that you could airbrush the laquer on and get a good finish. Unless you wanted to strip it. Years ago I tried to strip a laquer from a model. Used oven cleaner, industrial strength cleaner even brake fluid and none of them had any effect. When I found a stripper that would remove the paint it melted the plastic under it. You may have to log this one off as a learning experience. lol
