Just wondering how many people here use stencil cutters with their masking??
I like them as they are designed to cut only one piece of paper and also offer some good control while cutting the masks.
I recently aquired a two blade cutter but haveānt gotten around to using it. It looks as though it will cut very well when I do use it. My plan is to cut very thin strips of tape and or score plastic sheet with it.
I use the Olfa cutter, works well but I need to use little pressure when cutting the Tamiya masking tape.
My plan is to cut the tape when it is on the part, with a bit of practice I am sure that I can cut the mask only withouth leaving a mark on the part.
Back-end of the knife is used to lift the cut tape.
I use one occassionaly, but usually just use a new #11 X-acto.
Regards, Rick
