this is the polar lights 1/000 snap kit I built with landing gear deployed I used real sand from a beach for the base and and made the rock formations from hard pink foam that I cut with a box cutter and shaped with a Dremel with a sanding drum attachment then painted it sprinkled some diorama grass powder and I made the hot spring by sanding out a dip and different depths and using uv cured resin for the water and the steam was some cotton balls I pulled strands from and put in the resin before it fully cured
Very nicely done. My compliments.
thank you very much.
You don’t see too many Voyager spacecraft with the landing legs deployed - Nice!
Another great build well done ![]()
thank you once i found out this kit was able to be built with the legs deployed i knew i wanted to do a diorama with the ship landed on a surface of a planet
Very nicely done. I was surprised how you did the diorama
thank you very much .
