ST:TMP Drydock - Larger scale - WIP
October Updates 2014
September has been another busy month for drydock building. I was able to spend a lot of time on the Light Panel frame fronts. I had to cut out all of the plexi-glass pieces to use as clear windows and a 3rd piece of plexi for the graphic decals. For each light panel there are 2 pieces of plexi. That makes 112 pieces for each of the panels. The plexi was then cemented in place. I then had to make all of the decals which amounted to the same number of pieces. There are what I’m calling left and right side decals for each piece. There’s a slight variance between each of the decals, so I had to make sure they were all put on the appropriate sides.
I’ve also spent a great deal of time making the turnbuckle anchors and tension rods. One of my clients requested that this detail be physically bolted to the panels and the frames. So here’s how the work load pans out for this month. There are 504 tension rods needed for each drydock. These rods connect from the light panel to the panel frames. I am using styrene rods because they are very light weight. I’m spraying all of these rods “Rust” before I cut them to size. This way there will only be a minimum of touch-up work to do. On each end of these rods will be an anchor with a loop on the end of it. (See pics of this process in the October updates page) There are 2 of these anchors on each of these rods so I need to make 1008 of these. 336 of these anchors will be for the center tiers of the light panel frames. The remaining 672 have to be made with the end loops on a slight angle because of the way the top and bottom tiers are of the panel frames are curved. As of this posting I have the 336 anchor loops finished and will be working on the rest later in the week. The hard part is keeping track of how many of these have been done. The other dock will have just the sleeve part of the anchor loop on them so it will look more like the filming miniature version. Later when I start adding the rods to the model I will be able to touch up the unpainted surfaces.
In other areas… because of how repetitive some of this work is it’s nice to break off and work on something else for a while. For the last year and a half I’ve been contemplating on how I was going to build the work light arrays. On my 1/350 version I had no idea of how I was going to tackle this because of the complexity of these lights. In the end I wound up taking a piece of cardboard that had a mirror like surface on it. I cut it into a hexagon shape, then etched a lot of line into it and drilled holes for where the lights were supposed to be. I then back-lit this piece with 3 LEDs to make the lighting effect. Although I’ve hear some good suggestions of how and what to use for this array, such as a florescent light cover cut into a hexagon shape, it just did not work out for the scale I needed to build these arrays in. I have found some pictures of these light array panels and they were originally used in the unused TV series version of ST:Phase II drydock as the side panel lights. They have a very complex configuration and I wanted to at least in some way be able to come as close as I could to getting these as accurate as possible. I stumbled on the simplest of solutions. At my local Hobby Lobby I came across a section that has all kinds of beads, glitter and most importantly of all Sequins. They were in various colors and I happened to notice that the silver ones had a reflective quality as that of mirrors or reflectors that are used in lamps and/or flash lights. JACKPOT! They had 3 or 4 different sizes, so I bought a couple of small bags. I notices that even though they are punched out into round shapes, the center of each sequins had a hexagon shape to it. So I lined up 60 sequins of 2 different sizes of each kind of sequins then measured out the overall size of both of them and decided I had a close match for the work light arrays. When lined up properly with the edges of the hexagon they reflect light similar to what is seen in ST:TMP. So I built 4 of these panels 2 for each of the docks.
I cut out a hexagon shape made from sheet styrene, sprayed them FLAT BLACK, then carefully cemented one sequins at a time until all 60 were lined up and in there proper places. Next I drilled out all 60 centers of the sequins so that one LED could fit into each of the holes. It looks great so far and I can’t wait to wire them up and do a lighting test.
For the last part of my update: Since I was able to add the Starboard side of the light panels to the overhead modules I wanted to see how one of the Enterprise models looked inside of the dock so I snapped a few pics and put them into this month’s update. Hope you like them. MOre updates coming next month! See you then! Have a great month!
Mark
November Updates 2014
Hey Everyone!
I have some glitches to deal with on my website this month.
For some reason I’m having trouble uploading photos to my site so I’m setting up the photos to be in the Forum thread until I get things up and running again.
In this month’s update I’ve been working on the part of this model that I’ve been dreading, but need to complete. The assembly of all of the tension rods with turnbuckle anchors and nuts and bolts. There are 9 pieces per tension rod and there are 2,268 pieces that need to be put together on just the Starboard side of the dock alone. Each piece has to be cemented in place and aligned to each of the panel frames and light panels. Rather than just drilling holes into the Light panels and panel frames and running the tension rods through each of the holes and cementing them in place as I did with the 1/1350 scale PLE Dock My client has requested that the bolts on each of these connection be visible to give greater depth of scale to the final model. Detailing is very important to my client so this once again will slow down the completion of the Drydock. There is one shot of this detail that was visible in ST:TMP when the Enterprise was leaving the dock and the little dude in the space suit was waving good-bye to the ship. I now need to touch up all of the ends of these rods with Rust paint which will blend everything together. The pics show how this detail looks.
Another setback is the light panel lighting effects. After putting some reflective paper into the panels to defuse the light I discovered that this lighting effect would not work at all because you can see the EL wire behind the defusing paper. Bummer. I had to remove all of the EL wire and put in LEDs as I did with the 1/350 scale dock. So I’m now adding reflective tape to the backs of the inside of each light panel and will then have to hard-wire all of the LEDs in place. Not a very easy task at this point at least not with the Starboard side panels. Well, live and learn. We’ll see how far I can get with this within the next month or so. December is a very bad month for me to work on this project so there may be very little for the January update to show. But, enjoy the pics. I will try to have them set up on photobucket for now.
That’s it for now.
See you in a month.
Mark
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6546.jpg.html)](http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6547.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6549.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6550-Copy.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6551.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6552.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6554-Copy.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6555.jpg.html)]
(http://s185.photobucket.com/user/NemVia/media/November%20Updates%202014/100_6556.jpg.html)]
Okay, I was able to get the November updates loaded on my site just FYI. Sorry about the delay. Should be somewhat back to normal now! Thanks for your patience.
Mark
February Updates 2015
HELLO EVERYONE!
My apologies for the long interval between updates! December was a killer month for me as far as work goes! On top of that my mom had some health issues to deal with and then I was able to welcome 2 new grandson’s into the world! Yes, that’s a total of 7 grandchildren now! WOW!
Now on to the matters at hand! As I said December was a “Didn’t even look at the model” kinda month, But January was a lot more productive! I needed to get the armature ready for the Enterprise so I can marry both of the models together. I needed to do some major grinding and cutting in order to get the Armature to fit into the saucer section. The curvature of the lower hull became a bit if an issue. I needed to cut out 2 grooves on the bottom part of the armature in order for it to fit into the hull. I also needed to add some more holes into the armature in order to allow the wiring to run through to the Modules and down to the control panel that I will be adding to the model later on.
I also put together the Port side panel frame structure and ran all of the wiring through it so I can add the LEDs to it later on. After I finished this I started putting together all of the LEDs that will be used in all 56 of the light panels including the ones in the Overhead Modules. I also test fitted the Port side Panel frames to the Modules to see how they will look together with the Starboard side. So there was a lot of soldering going on during the month of January and there will be a lot more to come.
In other areas I finally got to the point where I needed the modules to be standing in their upright positions so I can get more of the model assembled so I started working on the display base. We had a couple of 40 degree days out by us so I was able to go into the garage and start working on the base. For the most part it is assembled together as you will see in the update pics for this month. The top of the base however is not permanently attached to the model as of yet until I can get all of the wiring and controls in place.
I’ve also started working on some additional lighting rails that run along the bottom of the lower tiers of the panel frames. This lighting is much like the ones that are on the bottom side of the Overhead Modules. There are also 4 more rails, 2 on each outside of the middle light panel tiers that will need to be made and mounted to the frames. Coming up will be some work on the mooring tractors on the bottom of the dock as well as some work that will be done on the work light panels and the work cranes. It starting to come together little by little but it’s looking good and I feel good about is being accomplished! There are 23 new pics on the FEBRUARY UPDATES page for this month! Hope you enjoy! And I’ll see you once again Next Month!
Take care!
Mark
March Updates: For this month’s update I was able to get a lot more wiring done for additional lighting effects. I have 25 new pics in this month update page. On the outsides of the dock there are 2 rails with lights on them that run the entire length of the dock. They are more accent lighting than anything, but they are there. I’ve also built 2 more rails with lights on them that run along the bottom sides of the dock. These are more visible in the movie. I have also started building the Mooring Tractor Beam emitters which steady the ship while it’s inside the dock. There are 4 of these that are seen in the movie and they are located on the bottom of the dock as well. There are also a few more details that need to be built before I actually mount the ship inside the dock. These include 6 outside mini panels (For what they are used for I have no idea, but you can see a great shot of them when the Enterprise leaves Drydock and the little dude is seen doing flips as the ship goes by) and I will be starting some work on the work crane and work light assemblies. These will be far different from the ones I made for the 1/350 scale dock. I will be making a master mold for these crane pieces so I can save some building time. I will also start work on the Gangway docking platform as it needs a lot of detail work on that. This piece might have to be made into casting mold as well. She’s starting to come together even more and I’m hoping this will wrap up in the next 3 or 4 months if there are no more delays. Keep checking for the latest updates and I’ll see you again in a month. Mark
April Updates 2015
This months update is quite extensive as far as the work done on the Drydock. To begin, I started by opaque-ing the Tractor emitters Flat Black. This took several coats because of the thinness of the styrene plastic. I had to make sure there would be no light leaks. I then painted the emitters Rust. But reviewing some of the Behind the scenes pics of the Drydock miniature and a few other sources I will be updating that color to a light brown color. I was then able to solder the wiring in place and connect it to the main frame of the Dock. All of the lights are working. I also was able to do a lot of touch-up work on all of the added pieces of styrene especially on the light panels and all of the detailing work around the entire panel frame assembly as well as all of the tension rods and turnbuckle assemblies. They are now a uniform Rust color. In addition to this I’ve also added the completed mark lighting rails that run along the outsides of the panel frames. These were soldered into their circuits and then painted to match the rest of the dock. The test lighting on this came out really nice!
The next part, or parts I was able to work on were the Cryo-tanks or whatever they’re called that run along the bottom of the lower tier of the panel frames. There are five tanks per cluster. I scratch built 5 different kinds of tanks with various smaller tanks attached to them. I then used this as a master for making molds. I needed 120 if these tanks for 2 separate models. I cast all of these in black resin then sprayed them a Light Gray primer. They were then detached from their main sprues and put in a pile on my work bench. Then I randomly selected 5 of these tanks for each cluster. These five tanks were attached to 2 mounting bands which allowed the tanks to form a half circle grouping. I then attached all of these clusters to the 6 separate joints along the bottoms of the lower panel frames. They turned out rather well. After I cemented them in place I did more touch up work on all of the tanks.
Another area I worked on was the work crane and work light turrets. These had to be built by scratch. I had purchased a mini-lathe specifically for this project and now I was finally going to use it. I took two wooden wheels that I purchased from Hobby Lobby and put them on the lathe and was able to create the basic shape for the turrets. The turrets resemble mini Jupiter II’s from LIS:TOS. After a nice light sanding they turned out perfect, but I found out that they were a bit too large for the scale, so I bought more of the wooden wheels in a smaller size and re-lathed 2 more pieces. It only took about 20 minutes to get the right shape. I then carved out a notch in one of these wheels. This is for the Boom arms that will extend out to the ship. The other wheel was made for the Gangway Docking Port. There are 2 docking ports on this piece and one on the work crane piece. I wanted to add some lighting effects on these turrets so I cast them I clear resin to all I would have to do is opaque the pieces and scrape of the paint where the lighting effect will need to be seen. The castings turned out very good. I am currently opaqueing them and then painting them a light tan color. There are 2 pieces for each of these turrets, this eliminated the need for me casting piece in a 2 piece mold, which is a lot of extra work. BTW there are 5 turrets for the work cranes and 2 for the work lights. I will alos be adding other details later on including the booms for the cranes and wiring and lighting as well as other small details. Most of this will be scratch built.
Another area I’ve started on are these 6 panels that run along the outside of the dock. There are 3 on the outside of each middle tier. Only 2 of them are really visible in the Drydock scene when Kirk and Scotty are in the travel pod. The only really clear shot of these panels are from a larger scale miniature that was built for a close up shot when the Enterprise is leaving the dock and the little dude is doing summer-salts as he’s waving goodbye to the ship. These parts will also have a small but noticeable lighting effect. I started this by cutting up some very thin clear plastic into squares. I used a behind the scenes photo of this as a reference as to how large these panels will be for this scale model. I have added some masking tape for the parts where the lighting will show through. There is some minor detailing that will be added later on, but this too is turning out very good.
Last but not least, I am also working on connecting the armature to the Enterprise. This armature will connect the Ship to the Dock. There will be a lot of tweaking for this armature because of the weight of the ship. It has to sit in the dock very parallel to the panel frames. So hopefully this will be something to look forward to in next month’s update. Otherwise there are 33 new progress pics in the April Updates 2015 page.
As always, enjoy the pics, comments and/or suggestions are always welcome. Take care and I’ll see you next month.
Mark
May Updates - 2015
Well, this month I wasn’t able to get as far as I would’ve liked to. I had several things I had to redo on the Enterprise model before I could start the wiring. I needed to add the Hanger bay doors to the back of the ship so they are in the open position. I also added a few more lightis to the hanger bay to enhance their lighting effects. But my primary task was to make sure that I was able to get the Armature mounted into the sauce and also make sure it would hold the ship up without bendig or bouncing too far up and down. The Enterprise does have some weight to it so I wanted to make sure the armature was holding the ship at an even keel. I also needed to start the wiring and have it feed through the armature up into the Drydock and down to the control panel base. This is now easy task as there are many wires to run through the ship. If this was mounted from below on the engineering deck it would a lot easier. But this ship needs to appear to be floating inside the dock and this is the only way to do it.
So I spent most of this last month doing a lot of soldering and wire running. Then after the wires were run thorugh the armature I needed to test that the ligthting circuits were working, then lable all of the wiring and the voltage for it’s final connections to the power sources. So, I got the Engineering section wired up as well as most of the upper and lower saucer pieces. I am waiting for a shipment of LEDs to complete the thruster wiring for the Main deflector housing. I was able to get the main deflector dish wired up and working. I have lighting tests pics for some of the ship’s lighting. By next month’s update I will have the Enterprise resting inside her drydock and then I can add the Port side of the dock to the model. Hang in there gang. It’s getting closer to being finished. I have 16 pics int the May Updates page. Check 'em out and enjoy! See you next month.
Mark
June Updates - 2015 Hey Everyone! It’s good to be back! We just came back from a week long cruise to the BAHAMAS! A much needed and relaxing vaca! Enough to recharge batteries and enthusiasm to get back to the task at hand. Anyway, I was going to set up the June updates before I left, but I ran out of time, so here we go… I needed to wait for some other parts for the model so I had to divide my time on working on the gangway/interface/armature and the port side detailing on the panel frames. I first had to feed all of the wiring through the armature and feed it up to the top of the armature so I could add the gangway and tower details around the wiring. This will hide all of the wiring and make it appear as though the ship is under it’s own power. I built the gangway on this version of the model the same way I did it for the 1/350 scale version of the model. I first started at the hull of the saucer section and work my way out to the tower section then build the actual tower section on three sides and detail it. By only building it up on three sides allows me to add any last minute additional wiring that might be needed. When I’m sure I won’t need to add anything I can then seal all of the wiring in and paint all of the details. I was also able to add the three hydraulic lines that are seen in the movie. I used an enhanced screen cap to follow how these lines hang on the sides of the gangway. In other areas I’ve added the lower tier mark lights as well as the port side mooring tractor beam turrets. So more soldering and wiring were needed. Also, I began working on the tension rod assemblies for the port side panel frames. I started with the mounting nuts then added the washers and bolts then cement the turnbuckles into place. Next I cement only one end of the tension rod into one end of the turnbuckle and leave the other end to slide in and out of the turnbuckle. This helps keep the rods from bending when I assemble the panel frames to the overhead modules when the weight of the structure shifts. The last pieces I’ve worked on in the last month are the outside panels that are seen when the Enterprise takes off from the Dock. I just added some small details. I put some c-channel pieces as well as some tanks on either side of the c-channels. I will be adding an LED to each of these panels later on to add some more lighting effects to the outside of the panel frames. Well, now that vacation is over with, it’s back to work on all counts! Enjoy the pics in which there are 12 new ones on the Updates for June - 2015 page! See you in a month! Mark http://www.NemVia.com 100_6709.JPG
July Updates - 2015
Hi my fellow model builders!
This month’s updates are now posted for your enjoyment. I have pretty much been doing a lot of clean up with the port side framework. I’m getting all of the tension rod assemblies in place as well as the port side mark light bars which run along the length of the model. I’ve also added all of the panel frame details to the sides of each of the panel frames. Everything is pretty much in place and all I have to do now is connect all of the wires and do a lighting test to make sure everything works okay. The only part I didn’t detail as of yet is between the top tier 2nd and 3rd panel frames. This is because I will have to cut into the tubing to allow the armature tower to fit in between these panels. I’m a little bit nervous about cutting into these tubes just because I don’t want to ruin anything. But this has to be done in order for the ship to be supported inside the dock.
In the meantime, I will be painting up all of the added details that I’ve put on this last month to match the rest of the dock model. In the updates there are 32 new pics for this month. I’ve taken more photos to show how the tension rods are added one by one into the structure. It takes about 40 to 45 minutes to complete one panel frame. This is mainly because of all of the small parts I’m using to build this part of the dock. I can’t tell you how many times I’ve wound up dropping parts while trying to put them all in place. I’ve also been doing some piece counting for the model. There are 9 parts to each of the tension rods. 2 mounting nuts, 2 mounting bolts, 2 washers 2 turnbuckle sleeves and one tension rod. There are 12 tension rods on each panel frame. So just for the tension rod assemblies alone there are 108 pieces per panel frame. 42 panel frames total including the port and starboard frameworks. This equals 4,536 individual pieces just for the panel frames alone. At the end of the entire build I will give you a complete total of all the individual parts needed for this model.
In other areas, I have scratch built some support clamps that are needed to hold the mark lighting rods in place on the outside of the port framework. These clamps were all cemented to the outside of the dock and aligned so that the entire length of the rod would appear straight over the entire length of the dock. The mark light rods are then snapped into the clamps holding them in place. Next I will be doing the wiring for these lights and then do a light test. After everything looks good I can then paint all of these parts to match the dock. I can finally move to get the Enterprise in place. Hope you enjoy all of the pics for this months. As always if you have any comments or questions I’d be happy to hear from you. See you next month! Be safe!
Mark
August Updates - 2015
Hello Everyone!
I apologize for the delay with this month’s updates. A lot going on in my life, lately! Whew! I finally am able to post the update! Anyway, Most of the past month I’ve been painting all of the turnbuckle assemblies on the inside as well as the outsides of the frames. No easy task considering they needed to be done one part at a time. Some parts needed more than one coat. I would have preferred to airbrush all of this but the masking would be too time consuming and the parts are way too fragile to keep in place. There are too many details on the light panels to worry about overspray and the like.
I have 9 new pics in the August Updates - 2015 page. This shows the painting completed. I’ve also added the cryo-tanks to the bottom tier of the frames and those are now secured in place as well. About half of the pics are some light test shots. The only other thing I was able to work on are the outside “B” panels. I’ve added a few more details to each of them. That’s pretty much it for this month, now let’s get that STARSHIP inside the dock and launch this puppy!
Thanks for being patient, See you next Update!
Mark
October Updates - 2015
I Apologize for the lack of updates for September, but Life Happens! Mom’s been in the hospital and a nursing home for the last Month and a half, I’m getting ready for a move and everything has been very hectic this past month - (phew)
The little I’ve been able to get done however is in the October Updates 2015 page. I found out that the pieces I cast for the Roof section of the overhead modules were apparently not thick enough to hold a flat shape. Some of them have warped a tiny bit, so instead of recasting all of them I had some pieces of c-channel left over from when I made the frames of the overhead modules and decided to use them for trusses to help keep any of the other panels from warping. The trusses are held in place with 2 screws. The trusses have also stiffened up the entire frame of the roof sections so it all worked out for the better on this build.
So I was able to paint up the top sides of all the roof panels the overall RUST color to match the rest of the dock. All of the panels are connected to the L-strips of aluminum so they can be dropped onto the overhead module assembly as well as be removed for any maintenance or additional details that need to be added to the module assemblies. There are 7 new pics for this month update. I know that’s a little weak on what was accomplished in the last couple of months, but now I can get back to the normal work routine of this build. Once again I apologize for the lack of updates, but I’ll have more to come for next months updates. Thanks for the patience and I’ll see you next month!
Mark
November Updates - 2015
Hi Everyone!
Thanks for your patience. I was able to move all of my model building stuff to my new location so after this update you will see some pics of my new work area. For this months update I have 15 new pics for you to view. I’ve been spending most of my time trying to mount and balance the Enterprise model into the Overhead modules. This scale ship weighs a lot more than the 1/350 scale version, so the issue of weight stands out a lot more in this build. I’m trying to get the Enterprise to appear as level with the drydock as possible so it will appear to be floating inside of it. It is taking a lot of tweaking to get it centered and balanced. After I get it as leve as possible I can then seal up the saucer section and permanently Secure the Enterprise armature to the Dock. Some of the pics in my update show how I’ve centered the model. Then I marked off all of the holes to drill for the mounting bolts. There will be three bolts holding the ship in place via the armature. I just had to take several pics of this. It just means I’m that much closer to finishing this build. I think you will like these pics.
Also I’ve begun measurements for the Hanger deck that is in the Overhead module. The Starboard side module will show the depth of the Hanger. This will also suggest that both modules actually look this way even though only one will have the doors in the opened position. I’ve taken all of the Shuttles Craft that I’ve cast both in opaque and clear castings and will be preparing them for painting. Some of the craft will be lighted up while others will be in a stand by mode. I’ve also cast many Travel pods and cargo containers as well as work bees. These will all be painted up and stored in the hanger.
Because of the framework of the overhead modules I will not be able to go as deep into the model with the hanger deck as I wanted. I was thinking of adding a mirror at the back end of the hanger to add some depth to it. I’ll see how this works out as I continue to add details to this part of the build. That’s it for this month. See you next Update. Take care,
Mark
February Updates - 2016 Okay! Finally I’ve been able to get some updates back on the site. I’ve started by adding 12 new pics to the February Updates- 2016 page. My primary work is for the Hanger bays seen on the front of the Overhead modules. My version of the dock will also include Hangers on the rear of the dock as well. The larger one will have the Hanger doors open so you can see into the hanger and view the storage containers as well as the work bees and shuttle craft that are stored there. After I finish the assembly of the hanger walls I will be working on the main hanger deck. I’m also adding a little more functionality to the smaller flight decks that are seen on the Starboard side module. I’, adding some access doors to the back walls to give them a little more depth. Thanks for your patience in all of this. I will have more updates coming next month! See you then!
Mark
March Updates - 2016
I’ve got a whole slew of pics for this months update! I’ve been concentrating on the larger hanger deck for the rear Starboard side of the overhead modules. As with the 1/350 scale version I’m adding a warehouse-like storage area for one side of the Modules. The front end of the Drydock will appear as it did in ST:TMP. The idea of showing the hanger is just to show what might possibly be on the interior of these modules. I figure that since the Enterprise is facing forward inside the dock it would make the most sense to have the supplies and cargo containers come out of the aft end of the modules to be loaded into the Shuttle Bay on the Enterprise. I’m trying to make this hanger a lot larger than the 1/350 scale version. I’m currently adding a lot of detailing to the walls and ceiling, etc. I’ve make some extra holes in both the deck and the ceiling for overhead lighting. As of this update I’ve pretty much have all of the wall details in place and I’ve begun spraying the parts both for light leaks and final colors. There are 30 pics in this month’s update. Take a look and let me know what you think! See you next month!
Mark
April Updates - 2016
This month I’ve been doing a lot of painting on all of the Overhead module hanger decks and entryways. The painting process can take quite a while because of all of the masking that needs to be done. All of the decks needed to have landing stripes and other colors added to them. I’ve been able to paint the main hanger deck and I think it looks pretty cool. It looks like a parking garage for the shuttles. I’ll be adding the shuttles, Work bees and cargo containers soon. Well I 52 pics in this months updates. I mainly showed how the painting process was done. Check them out and let me know what you think. We’ll see you in a month.
Mark
Very cool, somehow when I look at this I never seem to get around to commenting. Gee, I forgot how big this is till I went back and looked at your photos, a truely epic project!
You remind me of someone I use to contact at Paramount studios. awesome ideas…
July Updates - 2016
Great Apologies for the long delays… Many many issues going on at the moment including some difficulties with the Drydock. More specifically the Chase lighting for the hanger decks. I’ve been trying to use some optical fibers I had lying around, which would have made for some great lighting effects but, alas, the fibers were way too brittle for the complex bending that needed to be done in the limited space between the hanger deck and the modules. After the fibers snapped on more than one occasion I needed to take a little breather before I pulled all of my hair out. I needed to get a more durable optical fiber, which I did. I found several sizes that were relatively in-expensive. I used a 1mm thick optic fiber for the chase lighting effect. I bought 500’ of it hoping that will be more than enough. I still had some difficulty even with the thicker fibers, but I figures out a few different ways to bend them so they wont snap as easily. I first bundled the fibers according to their lighting pattern, then I put those fibers into a styrene sleeve. This would hold all of the fibers together so I can fish them through all of the holes that are on the landing deck. After that I could connect them to their respective LEDs and run them in their proper sequence. I also added some RED LED lighting for a warning track for the shuttles that are in standby for launching on the pad. I still need to straighten out some of the fibers, but the lighting effect is in place and working. Now I can continue on to the smaller hangers. I’ve also started painting up the Shuttles that will be seen inside the larger hanger. Some of them were cast in clear resin so I can have a lighting effect inside a few of them as well. Well, that’s it for now. I was able to get passed this massive hurtle, so now I should be able to get back to my stride once again. There are 17 new pics in the JULY 2016 Updates page and I will try to get a video of the chase lighting effect in place. Thank you again for your patience and I post more next month. Thanks everyone!
Mark
Here is the video update for the Drydock hanger chase lighting effects https://youtu.be/TUxS4FTIoZU
October Updates - 2016
Hey Everyone! No I didn’t fall off the grid, I’ve just been extremely busy these past few months. I’m still working on the Drydock, but what I accomplished during August and September was very minimal and not worth the update. But I have a significant update and I hope you’ll like it.
First off, I am still working on the lighting effects for the hanger bays. I’ve built some light sockets for the fiber optic effects, I’ve also been working on the shuttle craft that will be seen inside the open end hanger bay. They are all painted up and just need decals. I should be able to get those done by the next update. 4 of the shuttles will have some sort of lighting effect in them.
Next I took on the challenge of wiring together two sets of 60 LEDs for the work light Arrays. The soldering was very delicate and tricky. I needed to solder the wires as close to the LEDs as possible because there is a limited amount of space in the work light housing. I could have used the strip LEDs but they don’t have the shape I wanted for the actual light fixtures. After getting them all soldered together I took a few lighting test pics which came out really good.
Next I started building the housing for the work lights. These are scratch built pieces with some ribbing details on the backside of the housing. I made these so they would slide over the back of the lighting array. There are some touch-ups and puttying to do but they are finished.
Also in the scratch build department I needed to build the vertical boom arm pivots. This piece will slide into the Boom arm turrets and support the boom arms for the work cranes and work lights. I made a master to be molded with silicon rubber. I then cast 7 of these pieces for the turrets. I also drilled holes into the vertical pivot so I can add the boom arms and wiring.
Lastly I was able to scratch build the boom arms. I used some Plastrux tubing for the main part of the arm. I had to taper one end and lathe the other so it will have some interesting details. I also added some other details. Pieces that I call fins, as well as adding some eyelettes to the boom arms to support some thin rod pieces that come out of the vertical pivot. I don’t know what their function is but it makes for interesting details. I managed to complete the two work light booms and assemble the arrays to the boom assembly. Now I need to work on the turret mounts so that all of the work cranes can be connected to the panel frames in some manner.
There are 27 new pics in the October updates - 2016 page if you would like to see how the building process went. Well, that’s all for this month. Next month I should most of these items all painted up. See you then.
Mark
