squadron / model master / tamiya putties
Hi all,
Just curious what you all think about squadron, model master and tamiya putties.
Which do you use?
Which do you think is best and why?
Any special techniques?
Thanks
I prefer Tamiya’s. It sands and sticks really nice. The one thing is that the opening is very large, so you can not run a bead of it down a seam. Try to get some tools to apply it, so you can minimize sanding
All depends on the work being done. For general filling I always use Squadron’s white putty, but for larger jobs, Tamiya’s Basic Putty is great for the reasons that Jason described.
Cheers
Mo
As of right now I am using testers red putty and it does a perty good job.I have used squadrons in the past and it to was ok.I have also used putties from dap to what ever I can get a hold of.Most of these products are good depending on what job you want done,but as of right now the testors brand fills my need in what I need done.It has a medium dry time so that I can mold a shape to the things I work on,also used thinnly it has a quicker drying time for the seams.It scratches off easy and sands smooth to my needs.Digger
