I’m try to using some Tamiya Spray paint in my hobbyroom but the first time I did it really bothered my wife. This is even though I was spray in a home built spray booth with a 465 cfm fan. So here are the questions…
I live in Colorado where it is right now below… 0.F if I spray outside and then bring the model inside to dry will this be ok? P.S. altitude is 6500 ft above sea level.
Should I maybe just stick to airbrushing since then I can control the paint flow and not as much paint will be dumped at once?
Just a thought here: I like to use Tamiya’s Primer but I don’t like spray cans. I decant the Primer from the spray can into a jar. I then spray the primer in the jar using my airbrush. Less waste, less smell, better control. Maybe this would work for you. Let me know if you don’t know how to decant from a spray can.
There are two ways to decant the spray can that I know of. Here’s the first:
THE QUICK AND MESSY
Put tape over the opening of an empty bottle to seal it shut
Poke a small hole in the tape so that a drinking straw can be inserted through it
Insert the drinking straw through the hole
Hold or glue the other end of the straw to the nozzle on the spray can
Spray away
I don’t use this method because I can see myself making a real mess of things.
THE SLOW BUT EASY
Get 3 inch piece of 1/8 inch brass tubing
Take the nozzle of the spray can and drill an 1/8 hole into the nozzle
Insert the brass tubing into the nozzle and superglue it in place
Tape over the opening on an empty bottle
Poke a hole in the tape to allow the brass tubing to be inserted
Insert the tubing and spray away
Couple of things to watch for:
Only spray a little at a time
Only fill the bottle half way
The paint in the jar will be full of propellent. There are two ways to get the propellent out. You can just let the jar sit with the lid slightly open. This will take about 24 hours to get the propellent out. The other way is to GENTLY stir the paint. Be careful as the first time you put the stirrer in the paint, a lot of bubbles will come up from the paint. Stir slowly. Put the lid on the jar, give the a jar a little shake and crack the lid open to release the pressure. When you don’t hear the hissing of propellent being released when you crack the lid open, then you’re good to go.
This process might sound long winded but after you do it once, it’s real easy. Like I said, I used Tamiya’s Primer and I do this process on every model I make. It only takes me about 10 minutes to decant the paint and remove the propellent.
There’s an article by Matthew Usher in “How to Paint and Weather Scale Models” that shows the process.
