spitfire Mkv colors
What acrylic colors should I use? I use mainly MM Acryls. Or better yet, where is a good website to find my own info?
You can look here. It’s useful, but I don’t know when it was updated last.
http://www.ipmsstockholm.org/colorcharts/colorcharts.asp
Hi there,
RAF Dark Green & RAF Dark Earth are the standard upper camo colours, undersides camo will depend on what variant you are building, could be Sky or Med Sea Grey. Also where the Spit was operational makes a difference, as in some regions the Dark Green was replaced with Ocean Grey.
These might help.
http://www.jpsmodell.de/katalog/jpsraf_e.htm
http://www.rafweb.org/sqn_codes.htm
Google up - raf temperate land scheme & raf temperate sea scheme
I would think MM should do virtually all the needed colours for RAF camos.
Have fun with the build.
All the best,
Mick C.
Standard camo colours for the Spitfire Mk.V were Ocean Grey and Dark Green uppersurfaces, with Medium Sea Grey undersurfaces. In the Middle East/ Mediterranian, colours would normally be Mid Stone/ Dark Earth uppersurfaces, with Azure Blue undersurfaces.
By the time the Mk.V entered service, the Battle Of Britian camo colours of Dark Earth/ Dark Green/ Sky were no longer being used. It is possible, however, than some of the earliest non-cannon-armed Mk.Va s may have worn these colours, but not for a Mk. Vb or c.
Equivalents of these colours in a number of paint ranges may be found here:
http://ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_uk.htm
For Testors Model Master, the following are available in their Model Master II enamel range:
Ocean Grey: 2057
Dark Green: 2060
Medium Sea Grey: 2058
Mid Stone: 2052
Dark Earth: 2054
Azure Blue: 2048
Sky ‘S’ was sometimes used for spinners and tail recognition bands. MM II enamels have this as 2049.
There are no close matches for these colours in the MM acrylic range.
Cheers,
Chris.
Nope. The Spitfire Mk V entered service in early 1941 and the Land Temperate scheme was not replaced until August 1941.
The first production Spitfire Mk Vs were factory painted in the Land Temperate scheme, Dark Earth/Dark Green/Sky (Type S refers to the type of paint used - smooth instead of matt - not the colour. There were other Type S paints in use). Squadrons started reequipping with the Mk V from February 1941. From 16th August 1941 day fighters were instructed to be repainted in the new Day Fighter Scheme of Ocean Grey/Dark Green/Medium Sea Grey. This was to be done at the first convenient opportunity. From September 1941 manufacturers had to supply new aircraft in the Day Fighter scheme.
I found the colors in enamel only. I was hoping for acrylics. I also ordered them from testors.
If, and only if, you are building a Mk V(a) wouldit be correct to consider using Dark Earth.
The MkVb was only considered fit for front-line service after the cannon feed and other reliability issues had been resolved. It was, therefore, introduced to the squadrons after the change to day fighter colours, though a few months prior to the change to type ‘C’ roundels and fin flashes.
As far as Chris Hall’s use of the expression “Sky type S” is concerned, it reflects the most commonly published description of the correct colour and standard and was also used in some official documents to make the distinction. The same distinction was used to describe the correct specification of black to be used on bombers subsequent to the obsolescence of “Night”, which has come to be known as “Lamp Black” in more recent times.
W3207, an LFVB, first flew 12-5-41, went to 6MU 13-5-41, and was delivered to 609 Squadron 27-5-41, a full 3 months before the colour change, and was accompanied (or at least it arrived on the same day) by W3209, another LFVB. It was the IB which had all of the cannon feed problems, leading to their initial withdrawal, and mostly being returned to IA status. There were several IIBs, as well, P8312 - P8335 being examples, all of which flew in April, 1941, and were delivered in very quick time, too, mostly May, 1941.
Also, it was “Special Night” which was withdrawn during the war; “Night” remained in use until war’s end.
Edgar
I stand corrected, Edgar.
My apologies for relying on a very fallible memory and failing to check reality. (Blushing mightily).
I will stop putting my foot in it one day. I hope…
I don’t know if anyone stocks the Xtracrylix range over in the Colonies, but if they do, all the colours you need are available, as acrylics, in that range.
Cheers,
Chris.
By heck, I’m 67, and you should see the fool that I made of myself, recently, over a Spitfire in Malta; I always console myself with the thought “He who never makes a mistake, never makes anything.” Doesn’t always make me feel any better, though.
Edgar
Hi again WB,
Looks like the enamels are your only option, really don’t know why MM don’t do the full range of RAF colours in Acrylics, they seem to have enough Luftwaffe shades to camo a battleship. Apart from drying times you shouldn’t have any probs with enamels, they were the only thing anyone had a few years back. Hope the build etc. goes well, pop some pics up if you can so we, (over here in the UK) can see how those MM enamels turned out.
Best wishes,
Mick C.
What about Xtracrylix? Surely someone, in the U.S., is stocking them by now?
Edgar
Hi again WB,
Edgar, Two Bob’s is stocking Xtracrylic now. http://www.twobobs.net/
Looks like they have the full range, and certainly all the one you need WB, give them a try, they are most excellent acrylics.
All the best,
Mick C.
if you know of someone selling Xtracrylics on this side of ‘the pond’ please by all means provide a link or address, as I’m always looking for options in paint.
what you are looking for is Testors Model Master Acryl (note ‘ic’ dropped from description)
4840 Sky type ‘S’
4846 Dark Earth
4849 Dark Green
4850 RAF Interior Green
for Medium Sea Gray you can use 4757 Neutral Gray FS 36270 -you judge.
Pollyscale offers a complete line for you :
505250 Dark Green
505252 Dark Earth
505254 Sky type S
505256 Ocean Gray
505258 Sea Gray Medium
505260 Middlestone
505262 Azure Blue
505268 PRU blue (if you are doing a recon conversion
505270 Interior Grey green
