Spitfire Mk Vb Question
Hello everyone,
I’m new here, but have been back at the hobby for about a year and a half now. Quite a few kits full of mistakes, but it’s helped me learn quite a bit and improve a fair bit too.
At the moment, I’m working at tamiya’s spitfire mk vb from RAF 303 squadron (the Polish wing) for a friend of my Father’s of Polish descent. My end goal is to have it set on a small diorama with pilots scrambling around it (possibly even italeri’s new hurricane posed beside it in similar unit markings). I’m using quite a bit of Eduard’s photo etch and Ultracast’s control surfaces and Hispano cannons.
As I am using Eduard’s etch, I am planning to pose the unit with landing flaps opened. This begs my first question, does anyone out there know were the interior of the landing flaps painted the same RAF interior green as the cockpit by chance? I am assuming they would be, but I want to be historically accurate in this. My other question, along the same lines, does anyone know what color the interior / oleos of the landing gear were painted typically?
Having poked through the forums in the past, I think there are quite a few Spitfire aficionados out there, any help would be greatly appreciated.
Oleos are usually seen in an oiled polished natural metal. Landing gear struts and wells are a different matter and I do beleive it has to do with the time period. IIRC, painted aluminum was how the struts, wheel wells and wheel hubs were painted at the outbreak of war, as this was the specified color for the lower surfaces of RAF fighters before the Black & White identification colors were added. Later the struts and wells could be seen in the same color as the lower surface of the aircraft when the lower surface colors were changed to Sky,and later Sea Grey Medium. Wheel hubs are are almost always seen in Aluminum. Struts that were in Aluminum could also be seen with the undersurface colored wheel wells. So depending upon what year (1941-1943) you are planning is which of these guidelines to follow.
