Spitfire Mk.IXc (Monogram 1/48)
My last work is about the old Monogram’s 1/48 Spitfire (the model is of 1962). Although the shape is correct, the model is ruined because of two essential defects: over-heavy paneling with excess bolting (the surface of the Spitfire was very smooth in reality), and the canopy excessively thick.
The first defect of the two was easily removed, but the second was really a challenge. Using the original canopy as master, I thermoformed another identical using a heated sheet of acetate over a flame, next, with great care, I cut the copy with a very sharp cutter. The frames were made with plasticard.
All the interiors have been self-built using cardboard, plasticard, copper wire, and other material. Engine exhausts has been also self-constructed using copper wire rods. The wheels have been replaced with others with the right thickness, self-building the rims too.
The result of all this work, which has been committed to me for several months, is visible in the photos. I hope you will appreciate it.
The model represents the aircraft of Sdn.Ldr. Hugo T. Armstrong, of 611 Sqdn, who was shot down over Boulogne (F) on February 5, 1943.
(p.s. forgive me for my bad english)
That canopy came out clean, not easy to do when trying to mold over an open flame.
Very nice work.
Outstanding! You really did a nice job with an old kit.
Excellent work bringing that old kit up to more than acceptable standards. Very nice attention to detail, and the painting is spot on. Good job!
Yes Scottrc, you are absolutely right, it is very difficult to get a thermoformed copy as the original. I use a small self-built device to limit errors to a maximum. It is based on the principle of vac-u-form: it is a cubic-shaped wooden box with a metal grid at the top and a hole in one of the side faces.
The picture above should clarify the working principle.
Inside the hole apply the tube of a vacuum cleaner while it is on, and on the upper grid (where I have attached the master to thermoforming) apply a sheet of acetate already heated on a flame. To handle it better, the acetate sheet is fixed on a wooden telation on the edges. After some testing, and some adjustments, the copies are perfect. The only serious problem is to find acetate sheets of the right thickness wide enough to cover the top grid in full without leaving the sides empty.
Thank you templar :slight_smile:
Thank you very much Man :slight_smile:
Many many thanks Paladin :slight_smile:
Fantastic job. I really like how those exhaust tubes turned out. Thanks for sharing!
Thank you so much Greatmaker [:)]
That looks just fine. And your English is much better than my Italian
Nice sctratchbuilding, Vincenzo.
Outstanding job dressing up that classic kit. You have some serious talent!
The build and the painting are very well done. Thank you for posting this beautiful model
Hey, great job on a classic kit. Your exhaust stacks look great. I like how they look rusty. Great detail. Nice job.
Thank you very much Shamoo, you are really kind :slight_smile:
Thank you so much Jeaton :slight_smile:
Many many thanks Pusher :slight_smile:
Thank you very much Jay Jay
