Hey gang,
Follow my descent into madness as I build the X-15A-2.
The kit has nice detail thanks to 40+ resin parts and a sheet of PE. And even with all the included detail, there’s plenty more to add. The finished bird will be about 21" long - long enough not to fit in any of my display cabinets, so it’s another top sitter (like my visible B-17).
So, first up, we have the fuselage halves. The kit supplies resin dump tubes, but they’re easily broken. So, on the bottom half, I decided to use brass tubing. A little bit larger than the resin pieces, but infinitely stronger. For scale, that’s a 16" ruler in the middle
Next, a close-up of the Washburn Observatory’s Star Tracker camera system. It’s a complete scratchbuild. After seeing it the book “Hypersonic”, I knew I wanted to add it. The cameras are styrene rod that I hollowed out with the tip of an excato blade.
The ejection seat and pit tub. I cut out the side of the tub in the hopes of adding some wiring detail, but then realized it wouldn’t be visible after the seat was installed. The only scratched parts in this assembly are the hinges for the stabilizer wings on the seat. Just some PE metal cut to shape with rivet details added.
And finally, the landing bay and gear. OOB, there is absolutely no detail in the bay. So, after finding some pictures on prime portal, I added some detail that I thought would be interesting. Some internal bracing structures, the door control piston, some wiring and the insulation sheet. The gear had some decent resin detail, but there are prominent structures on the oleo that were omitted. So, I tried to build them from styrene. The shapes are close, but I think a bit over-sized. But I’m pretty happy with the way they turned out.
Next to come is trying to paint the pit. This is where I really wish Eduard had a color PE set for this. The blue-grey panel with the 300 black buttons is going to be tough. I’ll figure it out, but it won’t be fun to do. I’ll probably base coat in black, spray the top color and then sand the top color from the high points to reveal the black. In theory, this will work. In practice…that’s another story, LOL.
I should have started this thread sooner, but better late than never - right?
Till the next installment.
-Fred
