Admittedly I was struggling to get my head around your process, mainly because I’ve really had no exposure to this style of modelling. The videos are a very helpful explainer as to the work incolved! The results so far, although laborious appear to be very effective!
With this particular medium, are the models durable in the long term? Whenever I’ve used cardboard to make wargaming terrain or miniature basing materials, I had found a tendency to warp even in a low humidity environment like regional Australia.
Thankyou for sharing and I look forward to following your progress!
Thank you for being a frequent guest in this thread
You are spot on when it comes to the durability (or rather the lack of it) of cardboard models.
To make them “immune” to humidity and dust I spray them with matt or semi-matt Varnish once the model is completed. Obviously after I protect the paper with artists’ varnish from Winsor & Newton.
You can see it (hopefully) on my Ki-61 Hien. I think I posted the photos somewhere on this forum
I’m really enjoying following along with this build. Your videos are excellent; very informative. Now I know a lot more about how these paper models are built. Very cool!
You know, when I first looked at these pictures, I completely forgot I was looking at a paper model! At a glance, I thought you’d started working with plastic. And I’ve been following your builds, so I certainly know better!
The level of detail and craftsmanship you’re getting out of paper just continues to blow me away.
Sam, you are very kind Thank you. Its a shame that builds take so much time to assemble because I would be able to share much more in shorter time. Once I master the paper, one day I will maybe switch to plastic to build more realistic models / replicas.
If you were to ask me, I’d say sure, give plastic modeling a try! But don’t assume it’ll be any more realistic or any quicker. What you’re accomplishing with paper is already pretty remarkable. And I wouldn’t look at plastic as a replacement for what you’re doing, but rather an addition. I may give paper modeling a try myself someday, but I certainly wouldn’t give up plastic. I think the reverse could be true for you. Why not enjoy both?
And don’t apologize for how long your builds take! I’ve been working on two plastic models for almost a full year now, and I’m still not finished with either one. And I know there are plenty of modelers who take even longer. There’s no stopwatch running. It’s a hobby, and we’re supposed to enjoy it!
As our fellow forum member @fjs3 likes to remind us, “So many models, so little time!”
I second all of Sam’s comments. Your paper builds and so interesting in terms of construction - had no idea how these come together. And they look brilliant. Taking ones time is one of my simple mantras of building models: patience and clean hands.
There is nothing in your comment I can’t agree with I have a plastic Tamiya model of the Focke-Wulf which was given to me as a present some time ago so it will definatelly be assembled one day
Few of my fellow paper modelers moved to plastic models after few years, therefore in my perception it is a natural transition haha.
I need to keep reminding myself of what you said “that it is a hobby and we need to enjoy it and dont rush anything”. Rushing things it’s the worst thing we as modellers can do
I definitely want to try building a paper model at some point. You’ve certainly made me curious!
As for taking your time, I spent two and a half hours last night just fine-tuning the weathering on my F-4. I’ve come to accept that it’s all part of the fun. You know the old saying, it’s about the journey, not the destination!
The weathering on this model looks increadible. I know I have already mentioned this in a different thread but I cant get enough of looking at this Phantom
Thank you so much! It really means a lot. I’m trying out some new weathering techniques and learning as I go, so I’ve spent quite a bit of time experimenting with this one. It’s really nice to hear that the effort is paying off!
It’s been a while, but I can finally share the results of the last three weeks of work. This update is about the wings, which had me doubting myself deeply at times.
For the frame, I of course used laser-cut parts. They speed up the work considerably, and my part was limited to taking the pieces out of the sheet and sanding the edges so that everything fits together better.
Gluing the frame together was easy, although I admit I got a little lost at the very beginning: I couldn’t work out which side of the main spar was the top and which was the bottom. It happens to the best of us
Before gluing on the skin, I decided to fill the empty spaces with artistic foam. That way the skin won’t be damaged in the future if someone squeezes the wing too hard and presses the frame ribs into it.
I started by gluing the templates from the kit onto the foam. Once the glue had dried, I used a thermal knife that I bought recently for exactly this purpose. It cuts through the foam like butter, although this type of foam crumbles a lot and makes a mess.
After cutting, I reduced the thickness of the pieces by trimming off the excess foam and levelled the underside with sandpaper. Then came the first fitting and gluing all the parts into place on both sides. Finally, I sanded everything down to get the correct wing shape.
There’s nothing groundbreaking about the wheel wells: after cutting out the parts, I simply put them together.
Inspired by other modelers’ build reports of this aircraft, I decided to make the wells a bit more interesting.
Ribbed rubber hose: tin wire wound around a metal pin.
Rubber line: a piece of actual rubber tubing
With these extra lines, the wheel wells look much more interesting. Finally, I painted the new elements with a greyish paint to unify the whole well, as on the real aircraft.
Next, I glued the wheel wells in place. After the first fitting, I found a big gap right in the middle of the wing. At that moment I didn’t know whether it was my mistake or whether something was off with the laser-cut frame (most likely the former). To fix it, I tore the wheel wells off the wings and tried a different approach:
First, I glued the wing skin together using a narrow strip of paper.
After several test fittings to confirm that everything lined up, I glued the frame to the lower half of the wing.
I glued the wheel wells back into their original places.
For the upper half of the skin, I aligned the edges closer to the centre of the model and left a margin of about 1–2 mm near the wing tip, as the kit’s author recommends (I hope you know what I mean ). I secured the joints between the two halves with masking tape.
The wing is finally finished, and I’m happy with the result. The many hours spent on the wheel wells paid off, because they look great.
Wing tips are unfortunately still my weak spot. If you have any tips on how to shape them without two days of struggle, please share them in a comment below the post.
I had no idea the internal structure of these paper models was built up that way, with all those separate modular pieces forming the wing. Watching the framework come together is really fascinating.
I’m also curious about the outer skin. The side with all the rivets and weathering looks remarkably realistic. Is all of that detail printed directly onto the paper, or do you add any of the weathering and surface effects yourself after assembly?
Weathering is printed directly onto the paper. It obviously differs between the publishers but models from Mr.Halinski are known for their highest quality.
All I usually do, is only a layer of satin / matt varnish at the end of the build to protect the paper from dust and humidity.
For the wheel wells on the other hand I added cables and used brown wash to imitate stains
