PE work looks good. This one should be really nice when done.
That minigun must have been a hoot to assemble. Nice work all around so far.
Gino - Thank you - and also for your assistance to this point ! Greg - it really wasn’t bad …once l drilled out all 3 parts # 1 as well as 2,3 & 4 !!! And l still have 1 to go ! Wondering about a solve for the cargo hook / hell hole areas … Would it be correct to mount the hook to a short length of braid ?
Wow!
Truly impressive work! Looking forward to more pics.
That M-134 minigun turned out beautifully, 4x4! I took advantage of your advice to drill things out and the dry fits look promising. Thanks for the warning - much obliged. The rest of your build is looking sharp and I’m looking forward to seeing your progress on this project.
There wouldn’t be a cargo hook on a gunship. Extra weight you don’t need when you could carry more bullets!
Ray
Ray - thank you for your input !! Makes sense - of course !! Hoping to get some more pics posted - my past 3 days worth of spare time has gone into accurizing the " car doors " … have a bit more P/E to install & then primerPrimerPRIMER !!! Hoping to get the cabin , doors , pillars , ceiling & bulkheads & ammo box primed , pre-shaded & in paint by mid-week - then more detailling …aaaaand my construction business is HOPPING !!!
I got some primer shot last night … I decided to try a new ( for me anyway ) technique l want to call " reverse pre-shading " . I sprayed a black preshade where light would be the " brightest " and a bright white in the deeper areas and areas where l want the P/E to be spotlighted . Pics ( hopefully ) to follow - hoping to start the interior gray this evening
