Some of my projects...
Hello everyone.
First, let me say that I’m thrilled to be posting here, and I really look forward to learning from others and receiving critical feedback of my work. Since I primarily scratchbuild, I thought this would be a logical place to dip my toe into the pool. Now, I should say that my projects are a little more ‘toy-like’ in some ways, since that’s where my collecting has taken me in the past. What I’d like to do though is slow the process down, develop my skills, and become more disciplined so as to add a more scale-conscious, modelling approach to my final products.
I guess I’ll start with an earlier project…my 1/12th scale Snowspeeder. Now, this piece showcases my lack of planning and experience, since the cockpit has very little in the way of detailing (I didn’t plan ahead to make and created the whole body around the cockpit interior, thus blocking off my access to add layers of details). Also, the cooling fins on the back are unpainted since I assembled them before painting…and its very difficult to paint with a centimeter of clearance. I’m pretty sure also that, despite the fact that this thing is HUGE, I may have overscaled the ship and the height of the cockpit. It could also use a lot more in the greeblie department, and a more professional paint job. But, aside from all of these issues, the profile is pretty recognizable, and at the time I was quite happy with the overall impression.
Work in Progress
Basic styrene construction (assembled, puttied, and sanded):
Panels and detailing (thin styrene and odds and ends):
Primed!:
The Final Snowspeeder
The snowspeeder was hand painted with acrylics, and the weathering and battle damage was achieved with both washes and drybrushing.
Panel detail:
These image include some customs I made for scale. They’re based loosely off of Ralph McQuarrie designs, and stand about 6" tall (if you’re familar with Marvel Legends figures, I used parts from that toy line plus original sculpting for the bases).
Top:
And an admittedly bare and under-detailed bottom:
Next up is my Raiders of the Lost Ark Flying Wing. This project was…massive. I don’t have access to vacuum-forming equipment, and I tend to work on a very limited budget, so my solutions may not seem to be the most logical at times. But…this experimental nightmare ended up yielding an imperfect but very educational result. The landing gear is simplified, as is the cockpit, but I may return to those elements for an upgrade one of these days. Also, the scale of the model is roughly 1/18 scale (in line with the Hasbro Indiana Jones figures).
Process:
Since the shape of the Flying Wing is curved in a common tear drop shape that is universal among aircraft, I needed to approach construction in a different way from my usual box-like, modular fashion. The most obvious (but daunting) solution was to build it the way an actual aircraft is built…by creating a skeletal ‘airframe’ as a base:
This airframe is made from 060 styrense sheet, to give it rigidity. The wings were constructed in sections and screwed and glued together to make sure that the base was sturdy and strong.
Next, I made the c0ckpit section:
I designed the c0ckpit to be a separate module, so that I could work out the minimal details and proportions without having to handle the massive frame of the plane itself.
Using 020 thickness styrene sheet (a much thinner, therefore more flexible guage), I began surfacing the Flying Wing by gluing the properly sized and cut sheets to the underframe. This was mostly done by cursing, and by trial and error :slight_smile:
Added the wing tips:
Puttied, sanded, and primed:
This was an insanely involved project. I really used a lot of bad language while trying to make certain elements work, and I have to say its by far my most complex custom piece to date. There are a million little things that I’m unsatisfied with, but on the whole I’d have to say I’m pretty happy with the end result…especially since I was pretty much making it up as I was going along.
The finished product:
The wingspan, from tip to tip, is 38" and from stem to stern is about 16." Its really, really big. The engines are from an Episode 1 Naboo N1 Fighter, and the propellers are styrene…they can spin freely too!
The landing gear are made from the smallest casters I could find at the hardwar store. The front wheel has a swivel joint in it, which I thought was a fun addition.
The cockpit has space for a figure, and the gun turret has a removable dome to allow for a gunner to sit back there. Unfortunately, the figure needs to rest on its knees in order for this to work, but it looks okay when its closed up.
Scale shots:
And some fun ones:
The tank in Indiana Jones and the Last Crusade is, according to the makers of the film, a Mk. VII German tank from World War I. Such a tank never actually existed, since the design is obviously inspired by British, romboid-shaped tank design, and the presence of a turret is completely alien to any of the larger British tanks of the era.
Now…when I set out to make the tank, I was obviously doing so more from a gut feeling than anything else, since despite the presence of reference material, I got so many things wrong with regard to scale, shape, proportion, and level (or lack thereof) of detail. As a result, I sold my first attempt on ebay to make room for a second, more personally satisfying version. So here begins…A Tale of Two Tanks.
The First Tank
Work-in-Progress
Basic structure:
Base for treads added:
‘Riveting’ work:
The Final Product:
The Periscope:This thing was a mini-epic to build in itself!
First up, I drilled a hole in the top panel of the tank that was roughly the diameter of the styrene tubing for the main shaft of the periscope. The protective box is styrene, as is the periscope head itself. I found this tiny rubber gasket or washer in my fodder that would allow for the periscope shaft to hold a position when it was extended. The viewing part in the tank is a pair of binoculars from a clone trooper figure with some really thin styrene tube glued to the sided to simulate the handles.
I thought this was a fun little detail to add, though it ended up taking nearly a whole day to complete.
Now, I learned from this that the overall design was off model, and that I really needed to exercise more patience when it came to detailing. I was impressed with myself in some ways, but I wanted to take another kick at the can.
The Second Tank
Work in Progress:
The experience of making the first tank was a lot of fun, but it was also very difficult. It took me a month to complete, and I made many mistakes and had tonnes of setbacks. I kept adding to it, then realized that A) it was a tad too big for my tastes, and B) their were aesthetic elements to the basic structure that I wasn’t 100% pleased with. So, rather than continue to modify it, I decided to start from scratch. In contrast to the first version, I completed Tank 2 in one week.
Among the things that I wanted to change this time around was make sure the caterpillar track housing was more accurately shaped. I also wanted to make the thing smaller, though I thought my first one was kind of cool because it was so big (but really I just wanted something more accurate), and the big reason for my wanting to redo such a mammoth project was because I wanted to do a better job of detailing the interior. So, here it is:
The Exterior:
Looks pretty familiar, eh? Its shorter in terms of height and length, and the treads/caterpillar tracks are 1/2" narrower than the first. While I liked the proportions of my first tank better (especially the side gun ports and the overall length) this really is more what I wanted from the finished product.
Another big change from the first tank is that I wanted the side armour and panels to be more three dimensional, which requires more construction but looks much better.
The turret is also much more elegant in its construction, since I actually created a circular joint as opposed to using a screw (which worked well for the first tank, but I wanted to try something different).
The shovels are scratch-built using styrene card and rod…they’re not removable though, so Vogel can’t beat the crap out of Indy with them.
A couple of outside shots:
The Interior
With my first tank, I plunged ahead on the construction of the outer body, thinking I’d just detail the interior later. Unfortunately, the tank’s structure required more foresight than I thought, so as a result I ended up having a nicely done interior room with very little going on. The main problem was that the side guns needed to be accessed from the inside, and the way I built the treads blocked them completely off. Sooo…I had to accomodate the guns when building the treads this time, and also make some detailed guns:
The guns are more appropriately scaled this time as well, and are made from some plastic tube that I had lying around and some styrene rod and card.
The final product:
Thinking this through before construction really helped save time…all I had to do was completely remake the thing! Lots of doohickies and doodads and greeblies added as I went. The chair, guns, bench, and control console were based on very simple boxes constructed from styrene.
In much the same way that the periscope added a toy-like flavour to my first tank, I see this more detailed interior as doing the same thing for this version (though I did flub up and not leave enough room for the periscope this time around).
Comparison
Tank 1:
Tank 2:
Let me know what you think, and thanks for looking.
Those are some impressive projects! Especially like the “Raiders” plane, very cool! What is the wingspan of that monster in 1/18 scale?
Yea, I have to agree, those are very impressive. I can see how the snowspeeder is out of scale, the cockpit looks huge compared to the rest, seems more like a SD snow speeder of sorts, the paint job is good though.
The indian jones things though, those are just amazing. Absolutley astounding job.
Those are some great lookin’ projects! I really like the Indy build!!!
The wingspan is 38 inches…its pretty big.
Thanks for the feedback everyone. And I definitely agree Smeagol…the Snowspeeder is far too top-heavy. I may chop the cockpit down to accurize it a bit, and perhaps add more greeblie stuff to it.
More to come!
Id say against modifying your snowspeeder. IF anything make another, so you can really see how far you have progressed in your skill. I still have all (most) of my old kits on display, almost in a straight line of progression like an evolutionary chart
Having just built a flying model of a flying wing i know how much work is involved in one. That is a lovely model.
