“bathtub on wheels”! I like it![(-D] If the Japanese had sent that message/phrase on sighting them, it probably would not have had the same effect as their similar term did when they first saw them and they radioed higher HQ.
The Challenger is a SWEET build! I am taking my time to make sure all goes well. In the next week or so it should be taking final shape.
[XX]Luft-not so loud… cant be seen fraternizing…[:O]
Hi Stikpusher: vacation is good to knock out a lot of the “shelf queens”
Can I point one item out to you? The M4 Hybrid base of your Firefly IC had an engine crank hole on the upper rear bulkhead. Because of this, I’m pretty sure they didn’t mount the long storage box back there like they did with the M4A4 chasses. If they had it, they would’ve put it up on the glacis, I’m guessing.
Good call T-26! So much for Dragon’s instructions! All my materials show now stowage box on the tail plate and very few mounted on the glacis. I will correct the stowage box ASAP. This Firefly IC Hybrid I plan on marking as an Irish Guards vehicle during the late summer '44 drive to Brussels based on a photo in a Concord book that has no bow stowage box. Not to worry though, I have an old MB Models M4A4 hull that needs it…
