I just found out that my father in law was part of the ground crew for this aircraft during the tet offensive. I would like to build it for him, preferably in 48th scale. Does anyone know if there are decals available for that specific aircraft? I’m typically an armor modeler, so I’m a little out of my area here…
The Smithsonian F100D is BU# 56-3440. You can probably piece them together using this set.
Lots of other options as well.
If you have a Cricut or a Silhouette vinyl cutter, you can make the exact stencils you will need for the particular aircraft your father-in-law crewed. Or if another modeler in your area has a vinyl cutter to make the stencils for you.
