Skif BTR 152E Finished
First, let me start by saying that when you post on my build, give me the good the bad and the ugly. As long as its posed as constructive criticism, I’m willing, and wanting advice and criticism. Thanks. Well, the Skif kit didn have great fit, and the detail was pretty soft. So I decided to try my first attempt at PE, in this case it was Eduard. It was actually pretty fun, except for a few tiny pieces that made me want to toss all the little metal bits in the trash. The only stuff I added was a strectched sprue antennae, the six tire air pressure control hoses inside the interior, and the rods that hold up the windshield covers. Plus I added a rollled up a net, and added some “shells” althought They are very out of scale I realize.
So, here she is:
Sorry, I didnt have time to takea 360 view of it, so heres a few quick shots playing with lighting.
You can see some of the Edaurd PE detail in the guns here. The hollowed cone-shaped ?flash suppresors? came out great. It was my first PE attempt, so it could have been a lot better I know, but you can still see the great detail.
myself i think your btr looks pretty darn good in the photos,i like the used and abused look,the empty shell casings give a sense of action.i wouldnt mind having it in my collection at all.
Hey Ian, I think you did a great job on a not so great kit. The PE adds to the detail and helps the build stand up to more detailed models.The decals do stand out a bit, did you seal them with a gloss coat after you applied them? This usually protects them from washes or dusty weathering that can make the edges stand out. I like the shell casings in the back, and think that at this scale it doesnt really matter if the shells are a bit big, as long as they seem fine when you look at them. What did you make them out of?
Thanks for the comments! Yeah for the decals, I did the same as always, a coat of future before, then the decals, and then another coat of future. On the last few kits ive built that way they came out great, even with lots of light on them and from different angles, they looked perfectly painted on, so Im not sure what i did. Next time ill try a few smaller coats of future on them instead of just one maybe. For the shells, I took a piece of wire that i found in my basement, rolled it until it was straight using all kinds of tools, and then painted it brass. Then I just used wire cutters to cup it to size. Other than drying paint, took me about 20 minutes from start to finish, and i still have a whole conatainer left. As you can see, the wire cutter didnt give me straight cuts though, the edges are jagged, maybe a different type of cutting tool would work better. And the really detail obsessed guys drill the shells so theyre holow, for the ultimate realism. I dont have that kind of patience, but they would look great if some body did put the extra effort in.
Looks pretty good. The front end looks like it is sagging to me though. It just looks too low. Could be the angle of the pics though. I like the shell casings and extra details you added. Keep up the good work.
Yup, your completely right Gino, I hadtrouble attaching the chasis to the hull, (sorry i dont kno correct terms) and it ended up kinda like that. Ive been kinda considering putting it on a qucik base, probably just some sand/grass and maybe some tall field grass kinda stuff. Thanks for looking.
heya Ian[:)]-- no bad or ugly dude-- I think this is a pretty cool build[tup] – the vehicle itself appeals to me,your build up. finish,weathering and little extras( spent shells) all come together nicely for a very attractive looking job-- well done!!— tread[8D]
I think you did great with the PE Ian, definatly concidering it was your first, over all it looks like a well used vehicle which i like and the small things set it off nicely, like the casings. The main thing i would suggest is practice with your pics and lighting it looks kind of montone and i bet a lot of the detail is missing because of this, nice job.
Ron.
Thanks guys. yeah i really do need work on my photography. It seems like not enough light = monotone, and too much lighting = intesnse reddish tint.
I like this very much Ian. I have never seen this vehicle before, but like how you have weathered it and made it look well worn. Nice work.
Hey Ian,
Kit looks great and it definitely shows how hard you work to get this kind of result.
Doesn’t look too bad at all. I’ve always loved the look of this APC. Too bad the Skif kit is not at all that great. I think you did a good job with it. The tires need more subtle weathering. What I’d do, I’d give them a wash with medium toned browns, and very light beiges to replicate dust settling in all the crevices.
Thanks guys, and thanks for the idea zokkisima, Ive been looking for a way to do that. Im too cheap to buy pigments or anything like that so for the dust i used some kind of ground up chhalk, not pastels though. Anyways, the light beige wash sounds like just what im looking for, since the chalk didnt really stick in the tire crevices.
looks pretty good man! I can only second what everyone else has said!
