I put together some very cool buildings using the 1 inch basswood ideas for windows, etc. then i was going to spread Plaster of Paris on the walls, which I did. You probably already know this…while the plaster was drying it shrunk or contracted and bowed all of my buildings. See, now I was going to swear right there, but I didn’t…It’s a hobby.
Anyway, should I have laquered my little one inch pieces first? Primer?
Thanks, and we’ll try it again.
I work all the plaster and any other wet materials first, then add any wood, paper, etc.
Anything that would have sealed the wood prior to the plaster (which contains much water) might have helped. Also the drying time could have helped cause the warping. Good luck on your next attempt and let us know what happens as it could be a big help.
Richard
Basswood is not a good mix with “wet stuff”. You might want to think about using some luan or doorskin and using drywall compound. It will give you the same effect and isn’t as wet as plaster. Plaster will contract some but the warping most likely came from the water in the plaster. The other problem with basswood, sealed or not, is that it won’t do a good job of holding the plaster. There is no tooth or lathe for it to bind to. You would have to really score the wood, drill it, or add some screening to act as lathe so that it will adhere and have something to attach to. (The drywall comppound does so much better). Acrylic gesso or compound works better as it will flex some, even after dry. So it is an alternative to consider.
Luan as a base works so much better in that it has no grain, it is essentially plywood that can be from 1/8 to 1/4 inch thick. It is stable, tough, and is about the right scale for for some walls.
Plaster will sometimes crack as it dries and is really more of a mess than the effort warrants. Try the compound, it works easier, adheres well and looks just as good.
