MONGOOSE: Love the lighted carrier look, good work my friend! Now all you need to do is black out the rest of the room and have it appear to pitching around in the water [:O]
PAT: Your idea to cut out the hanger door is brilliant. That should make it easier to smooth the chizel cuts while also allowing you to add more detail to the door your building. I’m looking forward to the next update.
GAMERA: The pagoda of the superstructure has grown
I’ve added the Navigation and Range Finder Platforms to the structure. One thing, the stairs provided by Eduard between the different platforms were too short. This caused them to want to go near vertical and fall through the lower stairway beneath it. My solution was to use other PE stairs from my spares. That allowed the stairways to both reach the floor and do so at the proper angles. Could it be that the PE rooms between each deck were made too tall? Could it be that my PE bending expertise caused the problem (even though I did bend them on the fold lines)? One way or the other, they are fixed now.
In a related process I also added the Mk19 R.F./Dir tube from the top Range Finder platform to the bottom Flag Platform using plastic tubing from spares. This is more difficult than it looks as the tube touches another platform of the superstructure in a specific area. This means that I had to align the brass/P.E. buildings perfectly to each platform to allow the stairs and Mk19 gun director tubes to align correctly on each level. Not so easy without any guide pins, lines, or (?). Even the width of the stairway points on each platform had to me modified which could’ve easly changed the alignment of the PE on each platform. Then there was the cutting of the tubes to length and weaving my way into the assembly without disturbing or breaking anything already assembled.
Another update was adding the scratchbuilt R.D.F. Hut and a corresponding pole bracing the floor beneath. I did not add the handrail around its roof as the ships drawings do not show one there.
The Fore Mast Control Top is just sitting on the top of the front leg. I do not want to add it permenantly until the two other legs of the tripod mast are attached. I am not going to do that until I add the superstructure to the ship. Of course the superstructure is not going to be added until the splinter shields and 5" guns are added.
I have been working on the splinter shields as well but have nothing yet to show. I’ve also been working out where to add the small PE fire hoses, wiring, racks, etc. to the main and superstructure decks. More on these two items at the next update.
Thanks for looking in on my build…
Ben
