Hi
What are the best subtle weathering techniques when weathering a model ship? I only like light weathering otherwise it may ruin a model, I dont like to go overboard with it
Thanks
Hi
Thanks
I’m probably the LAST person you would want advise from on “subtle” weathering… I am surprised that I actaually can spell subtle. And I am assuming that this is for your Prince of Wales kit?
Anyway, I would recommend using acrylics on the main painting portion and then using enamel washes for your weathering.
Steve
Steve can you elaborate on why you suggest “enamel” washes as opposed to acrylic or oils?
I frequently mix up a batch of “rust” wash, and dribble down a line from the hawse holes and other openings in side of hull. This can be very subtle for navy ships. Civil ships can stand a lot more weathering- some look pretty sorry. I also use the wash on the anchor chains.
Getting a good patina on props is attractive. In spite of what kits call for, the props on large ships are NOT brass! They should be bronze. I paint them copper color, then a thin translucent coat of brown. Then I apply a green/gray wash.
Amen on the BRONZE props! EJ
I do something different .I have mixed up a batch of what I choose to call " Antique Bronze ’ Usung a dab of " Run-N-Buff " for a go by .
Tamiya X-33 bronze is a darker, copperish, reddish metallic. Vallejo bronze metallic 70.998 is more a darkish brassish color. With a wash of thinned Tamiya over the Vallejo, it kinda looks like the screws on the ESSEX did when she was in drydock in 1961/2. EJ
Anyone care to offer thoughts on why enamel for washes?
Because I have them, and the thinner, on my bench and don’t have to go somewhere to buy something else. I use enamels for my regular paints and have a good selection of colors on hand.
Generally, enamels and oils will dry slower than acrylics and you have more time to work with it to get the effect you are working towards.
