Sherman decals
I destroyed one of the decals for the Sherman I am building, the M4A3 with the 105mm Howitzer, from Tamiya. I am building it straight from the box and am using the decals for the 48th Tank Battalion, 14th Armored Division, 7th Army. I call Tamiya for a new decal sheet, but they said they were out, and to try back in a couple of weeks. Is there a aftermarket set availble? I need one of the stars with the circle around it.
Take a look at www.archertransfers.com They should have what you need.
I did that kit, but I am not sure what I have left as far as decals. I will check and let you know…If I have 'em, you can have 'em
You could also get some pre-cut Eduard masks, and paint it on. I’m not sure what size you need, but I think they have masks for the common sizes.
OK, they weren’t where I though they were, but I am pretty sure I have them. They are the ones with the broken circle, not the solid circle, right?? I didn’t use that set when doing my 105 but I kept the decals. Last I saw them was when I was using the decals for the stowage. I will keep looking.
Contact me offsite. You can have mine.
roy.chow@aya.yale.edu
