Sherman DD
I got the new dml LCT-3 and I’m building a new base to go with it. I wanted to put some kind of tank with it and when I came across this version of the sherman I got hooked.
Now the problem of building one. Is there any conversion or kit out there in 1/72 of it? Will I need to scratch it? also any reference pics will be helpful. Thanks it advance.
In 1/72, I doubt if there are any conversion kits available. If you wanted to try scratchbuilding DD gear fro an existing Sherman, start with the Italeri M4A1. It has the late model hull but with a 75mm gun. Although this combination wasn’t normally used, there were some Donald Ducks that were so fitted. Poke around the web for photos and drawings of the DD conversions.
I know I have seen a resin version in 1/76 but can’t find anything in 72nd.
Sherman would be a full load for a LCM(3) on a calm day. They built the later versions to better accomodate the Sherman. From what I have been reading (I got the dragon kit for Xmas), The (3) was pretty much used for troops on D-Day. Did bring in some softskins later in the day and afterwards.
thanks guys. If I build one i’ll have to scratch it. I will look into some the softskins and see what I can find.
