Self Propelled Artillery/Mortar GB 2006-2007
Welcome to the Self Propelled Artillery GB 2006-2007. Any form of SP arty is permited in any scale or kit , AM is allowed (just don’t go overboard please). Starts now (5th of October 06) and ends on the 30th of November 2007. AND HAVE FUN!!!
Heres the Badge courtesy of Yann Solo, you can wear it now.
Participants:
Will7813 - Trumpeter 1/35 AS-90 & Tamiya 1/35 Wespe
Comet - Maquette 1/35 Bishop
Espins1 - ??
Gun Tech - Trumpeter 1/35 H-39 10.5cm LeFH18 auf Geschutzwagen with the Eduard PE set.
Yann Solo - Tamiya 1/35 Wespe Self-Propelled Howitzer
PanzerWulff - DML 1/72 Hornisse
ewc2003 - Revell 1/35 PzH-2000
Shellback - Tamiya 1/35 Sturmtiger
Plastic_Cross - Academy 1/35 M-12
Privateer - Italeri 1/35 M110A2
Manic Moran - Revell 1/35 PzH2000 with Eduard PE set.
SgtBrown - Italeri 1/35 M110 A2 8" S.P. Cannon.
the Postman - DML 1/35 Hummel
Sorry for that. 1/35 Scale. I will also be using the Eduard PE.
All right. Count me in with my 1/35 Tamiya Wespe Self-Propelled Howitzer. OOTB
That’s a nice little gem of a kit. Well detail and good fit. Have you noticed the gun serial number on the breech ring? My jaw dropped when I noticed it.
Yes, that’s quite nice OOTB.
I’ll hit the hobby store this week and see what I can find. I’d really like to do a1/35 M7 Priest. Is the old Italeri kit the only option available? [?]
I already ask the question, here it is:
http://www.finescale.com/FSM/CS/forums/658024/ShowPost.aspx
Cool, thanks for the info Yann. I’ll see if I can snag one on e-bay, otherwise I’ll have to see if I can find something “on the shelf” at my LHS.
Hey Will I’m in I have a 1/72 DML Hornisse in the stash TTFN
Will, even though I have quite a few going on… the time limit is good. Put me down for Revell’s 1/35 PzH-2000. I saw this in an episode of “Future Weapons” on the Military Channel and it looks pretty cool.
He Matt! How did you managed to put that slideshow in your signature?
I take all my badges, standardize the image to 120x90 pixels, then use a GIF animation program and run them in 10 frame transitions at .05 sec per frame with a 1 sec frame for each badge.
Took a while to get it straight, and it’s starting to be a rather large file, so I may end up using the single badge, just optimized for web viewing.
All right, thanks.
OK, that was a good response. Everyone is added.
Will
This sounds interesting . I’ve never participated in a GB before . I was curriouse if the Sturmtiger assault mortar would qualify ? If not thats fine . I’m sure i have a kit of a self propelled howitzer in my stash. [:)]
Edit , oops , i see its self propelled artillery .
Shell
I don’t know, what sort of ranges was the Sturmtiger used at, and did it get given co-ordinates to fire at for the troops, or did it advance with the troops?
Will
The range for the Sturmtiger was about 4,600m… I would say that it might qualify. It used rocket assisted ammunition. And it not really a mortar, as these are usually smooth bored. The sturmtiger had a rifling to impregnate a rotating movement to the projectile to stabilise it and give it more range… and also used indirect fire… a bit like a artillerie piece…
I just wondered if the Selbstfahrlafette Sturer Emil would qualify?
I’m not up to speed with German WW2 armour but really fancy building one of these as they are on offer at my LHS and this GB would be a good excuse to buy one.[:D]
It qualifies as a heavy panzerjager… tank destroyer… not a self propelled howitzer. You should still get it though, as it is a good subject. I got mine in the stash and it looks big!!! Just waiting for free time to buid it. Yann did one not long ago, and it looked awesome!
Ok, I changed the name, and you can use the Sturmtiger because mortars are really just miniture artillery pieces, but keeping with the theme, it still has to be SP (Mortar carrying tanks, half-tracks, etc.). However, If a few people say the Sturmtiger shouldn’t be there, I’ll go with that, although I’ll keep the mortar thing. Comet - No, you can’t use the whateveritis, because it is a TD as Gun Tech said.
Will
