Seemless Sucker Intakes
I have tried several on line companies and am unable to find any one that carries the Seemless Sucker intakes. The SS website does not accept orders.
Any one know where I might find an on line supplier that carries them. I need two sets for the Tamiya 1/32 F-4.
Hay Bill i couldnt fins anything eaither but i did find this at ARC http://www.aircraftresourcecenter.com/ISL/Seamless_Suckers/F-4/F-4.htm
Well unfortunatly i found this out on CRMhobbies
<br><br>**SEAMLESS SUCKERS Resin Detail Kits**<br><br>
Until further notice we will not be carrying Seamless Suckers. The manufactorer has had some production problems and can not keep us supplied. I have not received a shipment in over 8 months. Hopefully this will be resolved and we can start carrying this wonderful product again. CRM
I might have found something Bill check this out says they have 3 instock
http://www.jjfpub.mb.ca/AircraftAccessories.htm
Buy the way its almost at the end just scroll down till you see Seamless Suckers
Doesnt Meteor Productions carry Seamless Suckers? Try www.meteorprod.com
The problem is those are 1/48 scale for UK F-4’s. I need two sets in 1/32 scale for the F-4 D/J.
They list them but when I try to order or access them, I get a message, “Item not found”.
Evan spruebrothers is haveing problems you might be SOL on those until the companey gets there problems worked out, but then again you might get lucky.
Hannants in the UK stock them
there about $20
Sorry got that wrong there the actual intake casings
I’ll ask around for you
Berny13:
I have an extra copy of Seemless Suckers intakes (SS-14) that I would be willing to sell. I had bought several copies a few years ago but will likely only do one 1/32 Phantom due to the size of the kit. Send me an email if you still need a copy of the intakes. I also have several of the 1/48 copies that I wont use (I went to almost all 1/72 scale) if anyone is interested.
(I’ll be traveling on business this week so I will not be able to respond until next weekend after today)
SS 14 is for the Revell kit. What I need is SS 15 for the Tamiay kit. The intakes for thr Revell kit will not work with the Tamaya kit. I have a set of SS 14 intakes to use with a 1/32 Scale RF-4C.
Hi Berny! Sorry 'bout that. I was just looking at my aftermarket list and while I note things such as the aircraft, scale and such, I didn’t note which kit it was for. I also have a copy of the Revell RF-4C kit so that explains why I would have an extra copy of the inraakes.
Good luck in your search for an Intake set for the Tamiya kit!
