Searching for a truck
I am looking for a 1950-1955 Chevrolet, Dodge or Ford 1 1/2 ton flatbed/stake truck 1/35th scale as used by the military at that time. Is there a model available or is there something I can modify to get what I need?
Thanks,
Richard
Good luck in your search. I do not have any informatioin for you. I know there some fellow modelers in this forum that build military trucks and might be able to help you out.
mark956
This truck kit is in 1/32 scale, close enough to 1/35. It is a standard stepside 1956 Ford pickup truck. Its capacity is probably ¾ to 1 ton though but since it is a slightly larger scale, you could fudge it and pretend it is a 1¼ ton truck. It is an old reissue kit. You could probably make a flat bed or stake truck out of it with a little styrene and balsa wood.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3176391085
Rob,
Thanks for the input it might work. I’ll check it out. Do you know of a military duce and a half from that same era (early 50’s) and tha same scale?
E-mail me RSaddlemire@sc.rr.com
Richard
Oldest post WW2 deuce on the market is the old Monogram M34. It is currently in a Revell of Germany box marketed with the old Monogram WW2 Jeep. It is called the M34 Tactical Truck and Jeep.
The tamiyia is goog for the years you are looking for that truck was still being used some by U.S. when I went to Nam in 68------Good Luck -----Stephen
