Scale-Master's Lola T-70 Mk-111 and My last Coast Guard Cutter
Just in case.
No he isn’t crazy. Scalemaster’s Lola is a pleasure to watch being Grown, Machined and Perfected. People told me I was Nuts! I took a Lindberg Coast Guard Cutter.Glued the hull together, sanded it down smooth and made a fibreglass copy for a mold. Drilled that puppy full of holes and vacuformed in reverse.
It came out great! Then I cut holes in it! Being that it was .030, it was thin enough to put the frames and stuff in it too. With the holes you could admire the Engine room full of two diesels and all the hardware to run them and the generator and through hull fittings for bilge pumps and coolant overflow .
I then proceeded to light all the compartments I detailed. This was for a Retirement Present for a friend who Commanded one. It was lit inside from a Battery pack in the base. So, I just want to say,see, there are those of us who really go all out sometimes. Try it, You’ll like it. You’ll stumble, but You will Get’er Done
