Sanding flat
I’d like to get some techniques everyone uses for sanding a surface of resin or plastic flat.
I use a piece of sandpaper on top of a piece of glass. However no matter how hard I try, the center or the object will always be the highest point. Sanding always causing the leading edge to get the most sanding.
Does anyone have a technique to combat this?
Try sanding in a circular motion it seems to help.
Or, the method we use with micromesh to remove damage from perspex canopies, figure of eight. It takes a bit of practice but should be effective for you.
Pete
Also, keep the pressure light, the sand paper still, and don’t use too coarse a grain, as if you overdo it, it’ll eat away too much material before you notice! [:o]
