I would like to share with you one of my favorites diorama. It’s called Rusty Ranch.
CONSTRUCTION
AMT – 1949 Mercury Coupe and MAISTO – 1903 Harley Davidson. Customized both vehicles. Also I distressed the balsa wood used on the fences. Entrance gate and mailbox is scratch built using styrene, leafs are mixed herbs. The base is a simple wood photo frame. The display box is made of 3mm crystal acrylic with laser engraved brand.
PAINTING & MARKINGS
First stage is priming with a base coat using aerosol can, then painting mainly with acrylic paint using either Vallejo and Tamiya paints. After base color is dried I use a mix of hairspray + chipped salt to achieve the rusty patina.Rusty patina achieved using acrylics, oils, rust powder pigments.
Wow! This is amazing. Not only that…but all the little details that you did. I would like to point out the image showing the broken rear window. That is masterfully done. Then in the same image, take a look at the drivers side rear flat tire, and the weathering done on that. In another image I even see some cobwebs.
That is wonderfully done! The weathering is outstanding. If you like critique, the only thing that I could offer is the chain locking the gate seems a little new for the scene, and that is really nitpicking.
