Next up to finish the second build of Roden’s kit #610. Using the other Loon resin set #LO32007 I proceed.
Moving on to the detailed late production build. This is the Old Propeller / wood & wire 5 color lozenge. Very similar to the the HGW but a bit less user friendly.
In the later production SSW D.III airframes the control yoke was changed to a Fokker type product. single handle with the auxilary throttle on the left side of the control column.
[color=#990000]The Avaittic crankcase being dry fitted to the Roden late production build. Modifications were made to the mounting base to match the Roden spindle.[/color]
Here is a list of the products used in this build.
Lozenge wing camouflage decals are from “Old propeller / Wood & Wire”. Wood grain for interior & exterior surfaces. “HGW”. Natural linen ribtapes laid under the lozenge to add rib detail from “HGW”. Detailing resin set from “Loon Models” a “Roll Models” subsidiary. (Cowling, wing tips, ailerons, horizontal stabilizer, elevator). LO32007. Brass PE detail set from “Hauler / Brengun”. An excellent product. BRL32014. Instrument Gauge faces from “Airscale.uk.co”. Instrument Bezels from “HGW”. Lap & shoulder harness’ from “HGW”. Spandau guns detailed with “Karaya” PE brass sets. National markings from the Roden kit #610. Rigging will be Cortland “Toothy Critter” leader material. Set #15.
Stock from the kit the overall diameter was too big by 1/32. So I cut the cylinder base down according to the instructions and used the image on the Avittic box top as a visual guide.
Now here I cut a smaller hole.I will put a stem of plastic sprue inside the Roden kit mounting spindle. The plastic sprue will act as further support for the rotary.
[color=#990000]Here it is. Just some touch ups and a couple minor details. The Aviattic SH.III resin motor went in with out too much fuss.[/color]
This Roden kit was detailed to one of the late production machines. It was probably 1609/18 and was assigned to ZAK 3 in Berlin for tests. It was photographed with a unique propeller that was considered experimental. It was made up of two dual bladed propellers that were notched and bolted together at the center hub. ( Fitting like like Lincoln Logs).
Lozenge wing camouflage decals from Old Propeller / Wood & Wire. Wood grain for interior & exterior surfaces from HGW. Natural linen ribtapes laid under the lozenge to add rib detail from HGW. Detailing resin set from Loon Models a Roll Models subsidiary. (Various types of late cowlings, engine support cage, horizontal stabilizer, elevator). LO32007. Brass PE detail set from Brengun. An excellent product. BRL32014. Instrument Gauge faces from Airscale.uk.co. Instrument Bezels from HGW. Lap & shoulder harness’ from HGW. Spandau guns detailed with Karaya PE brass sets. National markings from the Roden kit. Rigging is “Toothy Critter” leader material. Set #15.
