I am a beginner modeler and tried using a sharpie to make the rubber on the road wheels of my tank. It worked ok besides the glossy copper look. I thought this effect would go away after I sprayed on dullcote, however when I sprayed the glossy look went away but the marker started to bleed heavily. What am I doing wrong?
Personally I’ve never used a marker pen to do my road wheels but I have heard other modellers refer to this procedure. Why not just paint them? I’ve never had a problem with the paint bleeding as long as it is allowed enough time to cure. By the way I use Tamiya acrylics for all my models with a little model master acrylic thrown in for some detail painting.
Did you use a permanent marker or a dry erase marker? I’ve had good results using black permanent marker and then a top coat of PollyScale flat. If you used a dry erase or water based marker that may be why it bled when you applied the top coat.
Regards,
Chuck C.
I tried the Sharpie Marker a while back and was not happy with the effect.
I airbrush the entire road wheel with Tamiya Nato Black (a little less sharp then regular flat black). After it has dryed, i will then use a circle templat and airbrush the inner part of the road wheel the respected base coat. It works quite well and I recommend it. I got the technique from Chris “Panzer Dude” Mrosko.
I simply brush paint mine after the base color and camo is applied.Any “bleed- over” is simply GENTLY scraped away with a sharp blade after it dries.Brush painting road wheels is a good way to improve your brush painting skills,and improve your patience.It’s monotonous,tedious,and meditative!I usualy do it before I have to go to work when I have night shift.It gets my mind ready for a totally boring shift!I use Revell-Germany #9 Anthracite,It’s a pretty good match for tire rubber.
Brush painting is the only way to get a good result. Pick a new brush, not too soft and not too big and simply paint in long streaks, slowly turnibg the wheel. I have experienced that a 60/40 mix of semi-gloss black and a dull sand color gives the most lifelike worn rubber in 1/35.
