Does anyone know where i can order a "rosie the riveter "tool from ? Or does any other company make a similar pounce wheel type rivet maker ?
Plane Mad:
You should look for a Beading Tool Set (Grainers) - Very similar to a punch and die set but suitable for punching very small diameter holes (from 0.3mm to 1.25mm) in thin aluminum ot brass sheet. These are ideal for forming flush rivets in engine decks, or enabling the mass production of domed bolt and rivet heads. You can find these by looking for a jewellery tool supplier close to you.
Cheers;
Gregory
You might like to try here…
Its just out tomorrow,
http://smallshopeu.com/NUTTER%20PAGE%20page%20Page.htm
Alasdair
Be awair…I am connected with this so please do not follow the link if it offends you and you think it is just promotion !!.. I run the company !!
Alasdair
That’s a great looking tool. I would like to discuss further via email.
Cheers;
Gregory
The tool is out now…you can see here
For you and other Aircraft guys, the best thing about these being hollow is that if you dammage/remove rivets from area when you fill and smooth (joins at wing roots ect), you just use these OVER the kit ones and then complete the missing section…now that does save a bit of time ![]()
Some results
Cheers guys
Alasdair (Ali1kj)
The Small Shop EU
