Rigging tips
Doing rigging on the Reale de France now. Hadn’t done much rigging in over a year. Every time I do rigging after a layoff, I rediscover some of my techniques. Here are a couple of things it took me awhile to re-learn.
Be generous with thread length. If, for instance, you are strapping a block, even if the block will be close to a fixing point, leave lots of thread. If the attachment point is not that accessible, say towards the center of the deck, you will be glad for the extra length- you can bring thread out for knot tying, etc. I have a tendency to try to save thread. Thread is cheap- be generous. I have never regretted using a too-long piece of thread.
Wet the thread where you will be tying knots, or doing anything that requires a sharp bend in the thread. I keep a cup of water on bench, dip a finger in it and apply some water to a thread near these areas. Knots are tighter and stronger, thread makes sharp bend leaving blocks, deadeyes, etc.
Y’know, I’ve always wetted knots on fishing lines, but it has never occurred to me to so with model rigging.
I’m carting that idea away and keeping it–thanks!
wet the thread.i haven’t thought about that,a tip i really could use since i’ve had problems with knots untying themselves on my victory.
thank you don!
