I’m starting a Revell 1/24 Gunship build for my neighbor . What a great couple they are .
I looked for a 1/35 no luck , Only 1/24 scale …
I done alot research and that’s what lead me to your site . What a great site this is.
Thank you all for having me .
Start off . This weekend I will start the primer process . Not sure which primer . Looks like i’m just going stay with tamiya acrylic paint .( air brush ). l will just try to match the colors best as possible . Then follow up with a weather wash with Promodeler wash . .
This week I been working on striping the chrome piece . I soaked them in coke cola .Used 2 cans
Here is some pictures. 3 day soak
3 rd picture .This will go back into the coke for more soak time . tell this weekend .
Will, I got some airbrushing finished today . Here some pictures
Last night I washed the parts off with hot water with dawn . Let dry over night .Before spraying , I Wipe sprayed parts with 90% alcohol
Last
I have always eyeballed and wondered about this kit… This should be fun to watch.
Need some advice here please .
Tomorrow can I tape off the back and front seat and apply 2nd color ? Red
I also bought this kit recently.
I look forward to viewing your build.[:D][Y]
Welcome, Rick, and kudos on a great job so far. Will be following this one with interest.
If I may offer a tip for future use–assuming you haven’t already encountered it–regarding stripping the chrome from model parts. A spray of Easy Off (or similar oven cleaner) will do in minutes what the Coke took several days to do, with no damage to the plastic parts. A quick rinse (and, occasionally, a little old-toothbrush action for the stubborn bits) and the parts are ready to use.
Have you decided on markings or decals yet?
Thanks all Have you decided on markings or decals yet? No not yet This will be a long build . I hope to have it done by Christmas . This is my first build model . The back seat . Under it there is a box . I think it holds ammo. Is that box dark gray ? Thanks
Most of the morning . I was trying to figure out how to mount the parts and spray . I never work with small parts like this before . I went in the junk box found a alligator clip , I crimped a 12 gauge hard wire to it . Omg perfect . Then I took those green foam blocks from my daughter . I sprayed the parts 2 coats , then pushed the wire into the foam block . Done . I do need gloves . Oops . Learn something . Painted hands
Rick G
Thanks
Yes, if your are going to be masking, it is best to let painted parts dry overnight. The cans uder the seat are ammo cans for the machine guns- those should be painted Olive Drab.
Today’s update .Spent almost 2 hours taping .
The Gauge panel ,Just the top is painted flat black . The ammo box painted olive drab
