I’ve built this kit before (1/48), and am working on another one, and am running across the same problem - how do you get the wings to fit to the stubs on the fuselage correctly? Last time and thi time also, the wing to fuselage fit is terrible, and leaves a big gap or ridge. If you glue the top wing pieces to the bottom and then to the fuselage as per the instructions, the top of the wing is too low and leaves a big ridge where it meets the base on the fuselage. I’ve tried to fit the top wing pieces to the fuselage first, and then attach the bottom section to them, but the edges that attach at the tops are very thin annd don’t fit well in the first place.
Those of you who have built this model before - how did you deal with this? I/ve thought of perhaps tring to glue locating rods or something in place, but am not sure yet on what to do. Any and all suggestions are welcome. I’m trying to make a collection of the major versions of the P-40 that were used in WWII, and need the B version for my first one. Is there a better B kit out there by somebody else? How is the Academy C version? Is there that much difference betweeen a B and a C?
Thanks for any help you might be able to give me!
John
