Revell Germany Eurofighter/ Tyhoon 1:32
Wondering was their anyone out there who has worked on this model project, I’d really like some tips and maybe some other brand products to improve the overall model, I’m working on a skill level 5 & I want this to be as perfect as I can made it.
It’s a putty monster.Very big kit and very detail cockpit .Make sure you preFit the cockpit tub assembly…Comes w/ detail engine .Typical Revell Germany.Very large decal sheet.
It has a very good instruction sheet .Many versions.It will take you about two days to apply the decals.Nose weight needed.My 12 year old grandson completed this kit also.Now I have 2 models on display.It will make a good entry model for display or contest.
I made this model some years back and I took 5 months building it, depending on how accurate you want the model to be will depend on how much work you will want to put into it, the seams at the wing root are on panel lines but are really wide and will need a bit of filler, it’s a great kit and has basically everything in the box you’ll need for a fantastic looking model, as with Revell kit’s in my experience on a large scale, if you’re prepared to put in a lot of work you’ll have a great looking kit. I would only recommend the landing gear be replaced as the nose wheel is sturdy but the SAC version is a much better option, other wise I would say replace the decals as they’re far far too thick. But that’s it.
