Revell Germany A380
Hello all,
Has anyone built, or is there a review out about the RG A380? I am working on the Emirates version and so far, with my guess you would call primitive skills, it is coming together quite nicely. Thank you for your help
cheers
Scott
At the ‘Aircraft Resource Center’ website, there is an incredible build of the A-380. Cockpit lighting, photoetched fan blades, great diorama. You have to see it to believe it. I cant get a link in here, but its at Aircraft Resource Center-Gallery-Jet Aircraft-Airliners, and then look for the three part A-380 build. You’ll be glad (or sad ) you did.
thank you very much, i will be sure and check it out!
Which scale?
Peewee
I have built that. The only problem I remember is the piece that goes on the bottom between the wings. And once I was fishished all my wheels didn’t sit nice and square on the ground.
I was impresed with the shape of the wing and I thought the decals were great.
thank you for your input…i am dealing with that piece right now. I am making the gear up on this on, but will have a gear down version later. I am looking forward to how the decals will look
Getting all of the tires to sit, or touch, evenly on the ground is difficult to do even with the various die cast and the Sky Marks resin versions. The same goes for the 747s.
Peewee
