Revell 1/48 P-61 Black Widow, "Midnight Mickey" - Work in progress
Hi Gary,
You said it man, a lot of work on this one! :slight_smile:
The subject is what keeps me going, as I love this aircraft. :slight_smile: When you get over the kit quality and forget great expectations (speaking for myself and my average skill level), it’s actually very fun to build, but one really needs patience which I often lack these days having two little kids, haha. I kind of see it as fun practice. We’ll see how she turns out in the end.
I recently oredered two of Hobby Boss’s 1/72 widows with which I expect no trouble and just fun :slight_smile:
Thanks for the encouragement! :slight_smile:
Good luck to you as well! Looking forward to seeing your work!
Cheers,
Nikola
Hi Brynn,
So far I only heard of vacuforming and have no idea how it works. It sounded complicated to me. :slight_smile:
Now that you mention it, I will research it a bit and maybe try it on future builds if needed.
Thanks for the tip!
Best,
Nikola
Wow - those fit issues look challenging. It’s looking good though – keep charging.
Hi Hoss,
Yes, it has a lot of fit issues. No wonder why it became a notorious kit. Very fun subject to build though. :slight_smile:
I finished all of the filling and sanding work, so now off to priming. Yay! :slight_smile:
Cheers,
Nikola
Oh Boy;
Now I know why when I had my Vac-U-Form by Mattel everyone wanted canopies. I have built that kit twice in the original Black Moldings. I don’t remember that drastic a set of fit issues. It’s almost as if the clear plastic shrunk catostrophicly!
Why? Who knows?
Hi guys,
Priming and complementary pre-shading finished:
  1. Primer - Vallejo German Dark Yellow Surface Primer 73.604
  2. Complementary pre-shading - Tamiya XF-7 Flat Red (and darker shade of it made by mixing with XF-1 Flat Black) and X-16 Purple.
  3. Highlights - Tamiya XF-55 Deck Tan
Next step: Base colors - Tamiya XF-62 Olive Drab and XF-53 Neutral Gray.
Thanks for looking.
Cheers,
Nikola
Hi gents,
Here she is with the first set of thin coats of base color (Tamiya’s XF-62 Olive Drab) over the complementary pre-shading scheme.
I think that the color variation should be subtler so I might go with a couple of more thin coats of OD or go straight to filters and do it that way.
I will decide on that when I see the model tomorrow in daylight. :)
Apologies for the image quality.
Thanks for looking!
Cheers,
Nikola
Hi gents,
Update on the Widow:
She received a second set of very thin coats (85%, thinner) this time those being Tamiya XF-59 Desert Yellow. I chose to lighten the OD with a yellow since OD is actually a mixture of yellow and black.
The first couple of photos are taken outside in daylight and the rest is from the study. This is as close as I could get to showing what I actually see in reality without taking fancy photos. :)
The effect of complementary pre-shading is subtle, but I think that it does add richness to the color scheme of the model.
Criticism and comments are more than welcome!
Again, thanks for looking!
Cheers,
Nikola
Nice effect, very convincing fading look.
Very good. The sunlight brings out the shading very well.
Gary
Thank you Jeaton! Glad you like it. :slight_smile:
Best,
Nikola
Thanks Gary!
We’ll see how this outcome handles the next steps of washes amd filters.
Cheers,
Nikola
I’m learning a lot from this about using different colors for pre shading. I guess it’s not just black anymore
Hi Tempestjohnny,
Thanks a lot! I am glad that you find my method interesting. Appreciated!
I think that it opens up a lot of possibilities for interesting color interplay, but one should be careful and keep it subtle so it doesn’t look unrealistic.
Cheers,
Nikola
It looks like you’re beating that bad boy into submission. I like the tarp idea. Great solution. Certainly better than ripping all the hair out of your head trying to get that fit.
Yes and the big O² bottle on the other side was yellow.
Also, on the starboard side panel details you painted the in-flight O² supply hoses for each crew position silver, when in fact they were actually flat green.
This post continues to be a trip down memory lane for me, as I remember building this kit when it was in the Monogram box, and being very much daunted by the glossy, four-page Shep Payne diorama included in the box.
I remember skipping the red decals and simply painting the upper surfaces red and masking off the red stripes on one of the all black-versions. That would be about 1980, before we had chipping medium, AM accessories, and the like.
Hi CapnMac,
Glad it brings good old memories to you. It really is a timetravel kit, haha :slight_smile:
Cheers,
Nikola
