Here are the final photos of my 1/48 Revell P-38J (vintage 1964 [#toast]) right before I put it into the display case. There are some major fit issues with the kit, but if you’re patient and have seam filling skills you’ll be good to go. There is no way on God’s green earth though that you can get all the canopy parts to fit properly, they’re just not shaped correctly for that to happen. [(-D] I chose to build mine as the one flown by Major Richard Bong.
I built this kit as part of the Secret Santa GB hosted by jwb (Jon) which was a lot of fun! [:D]
Espins, that’s what I found on my Marge, too. I’m gonna do the same kit again, though, in the P-38 GB. I learned enough from this one that I think I can do better. I’ll not be beaten by a few pieces of molded plastic[:(!]!
I didn’t do anything special, just carefully airbrushed some Tamiya XF-16 Flat Aluminum all over. [:)]
I’m not sure how heavy each weight was. I have a set of miscellaneous, conical shaped lead weights. I used two each of the biggest and glued them inside the front of each engine nacelle which turned out to be more than enough to keep the nose down. I used CA to secure them. You can kinda see them in this photo.
