Revell 1:32 BAe Hawk T1.A Red Arrows.......Finished!
She’s looking great Steve! As for your lettering problem, I was going to suggest an aftermarket set of letters or perhaps an aftermarket set of decals but there are no letter sets in the correct font or decals for the Red Arrows. If you have or know someone with a Cricket (a small home printer sized device that cuts vinyl stencils and masks for diy projects), you could import the image of the letters and create a mask. You could also go old school and create a mask yourself by tracing the letters onto a piece Kabuki tape, and then transfer it to the model. There are several good videos on YouTube showing you how to do this.
Blimey - you don’t need any help in that department, that’s for sure! Do you use the narrow bendy masking tape for the curves or cut them from wider stuff?
I can’t offer any thoughts on the lettering - sorry.
Hi Lewbud, thanks for the kind words and suggestions.
Unfortunatley, I neither have nor know of anyone who has one of those cricut machines. Neither do I have the know-how or software that I have seen/heard be used by others.
The old school method you mention, a kabuki mask…that sounds like REALLY hard work!! Can you share/suggest youtube link…I tried a few search in YT but just seem to find good old face masks!! Might not be as bad as I imagine if I can see someone doing it [:S]
Hey Hutch,
I use the bendy vinyl like stuff from Tamiya. I have 3 different sizes, 2,3 & 5mm. I use the 2mm to mask the lines then fill in with regular masking tape to prevent overspray (though some always seems to get thru somewhere!!)
Have actually just come in from the shed having masked off the other side, hopefully get that sprayed tomorrow.
Schools still out on the lettering…[^o)][*-)]
Steve,
Try this. https://youtu.be/oAPlXs7pD3E
I thought of another idea, buy another kit and stack the decals. Probably not an optimal solution, but it is an option.
Thanks, Steve - I may invest in some of that, e.g. for the camo on my V-bombers (if & when I ever get round to them!) - overspray’s a b****r, isn’t it?
Cheers,
Hutch
Hi Lewbud,
I had already thought about double stacking the decals, just that I couldn’t find another set anywhere (except buying a new kit). However, I found a kind soul on another forum (BM) who is going to send me the decals as he hasn’t used them on his build…what a great result…and a VERY kind soul.
Also, thanks for the link, suddenly doesn’t seem like such a hard thing to do, but certainly not easy [;)]
It certainly is!
Steve,
Glad to hear that a kind soul came to your rescue. I haven’t tried it either, but kind of want to give it a shot. I look forward to seeing your finished build.
First lot of decals on, just need the second set to go on top of the ‘Royal Air Force’. Thanks a bunch to a fellow modeller on another forum, I received a second set in the post this morning.
Unfortunately, they will have to wait for a few weeks as I have to go to Poland for business for 3 weeks tomorrow. Not sure if I’m looking forward to it or not, this is my first work trip since March!!
Anyhoo…will try get a clear coat over the top later today if I can, need to seal the decals before I put the second ones over the top. I figure it won’t work well for me if I just put them straight over the top as I expect the decalfix will affect the underlying decal.
Most all of the decals have worked out just fine, but you will see that the Royal Air Force is ‘pinking’…hence the second ones to go over the top which I am sincerely hoping will end up proper white!
also, the wooden base I have ordered will have arrived and I can mount the clear acrylid rod (in 1st pic) so I can display it in flight.
Looks beautiful. Painting on the arrow was the way to go. I’m sure with a 2nd set of decals even the letters will look great. red is such a hard color to work with. That det cord work is astounding. Never seen someone domsuch a nice job on that.
Thank you Mongoose,
Have now made it back to UK from my business trip so I can finish this up. As you will see below, started putting the 2nd set of decals over the top and it is doing the trick!
As for the det cord, first the canopy was dipped in Future, then copious amounts of Microset/sol used and the det cord decal was put on the inside of the canopy. Once all settled and dry, the whole canopy was rubbed down with 12,000 micro-mesh and then dipped in Future again.
So here it is, finished at last.
Just a couple of photos, will get some better ones tomorrow in daylight. Toying with the idea of using some cotton wool to simulate a display smoke trail. I’ll play with that idea tomorrow and see what it looks like :slight_smile:
Outstanding work Steve…
Looks good Steve![Y]
You made A winner out of that! Andi can see the det cord just enough to be realistic looking in that last pic. Super
Thanks for the kind words guys, much appreciated. Will get a few more photos up tomorrow, weather today was not condusive to outdoors shots :frowning:
Came out great. Base is awesome
That’s an amazing build. The paint job is awesome!
Your friend’s, Toshi & Ezra
thanks Tosh [:D]
