restoring a scratchbuilt Ohio riverboat model
I have a scratchbuilt model of an Ohio riverboat that, upon falling from a shelf, experienced some significant, but reparable damage. My question is in regard to materials and methods…to wit: what does one use in today’s model building world for rigging lines?..the original–thread stiffened with airplane dope? or is there a better method?
IMHO for a restoration as much original material as possible should be used. You don’t say how old the model is but for thread, I’d think about plain old cotton thread drawn through a block of beeswax to keep it from getting “fuzzy” looking. Good luck with your project Ray I just noticed that this is your first post. Welcome to the forums and to a group of friendly, knowledgeable people. R
Depends on the scale, but unless the scale is much smaller than usual for a riverboat, I’d think sewing thread would be appropriate- either cotton or rayon. I use monofilament stuff on very small scale, but most riverboats were small enough that I have seen very few in a small scale, say smaller than 1:350.
Silk thread doesn’t fray.
Thanks, I’ll try it.
…and what’s the best sort of glue to use to reconnect the parts that have broken off?
Thanks for your help & comments
Thanks for your comments and advice
For glue for the repairs, CA is great because it sets so fast. If the breaks are clean, regular CA is okay. If there is a rough surface, use gel CA.
BTW, forgot to mention in first post- do NOT stiffen the thread. Better to leave it limp and merely tension it when you run the lines.
I must ask , are you the fellow who posted on another site and also sent a picture of the damage ? If so . then welcome here . I do believe I stated at that time I would guide you through the repairs if you wished . That offer still stands . Contact me offsite at gjgeracci@satx.rr.com thanks . tankerbuilder
