Resin Parts
I began casting my own resin parts several months ago, and I have discovered a problem when it gets time to paint. I am finding that the resin is bleeding through the paint, even though I wash the parts prior to painting. Do I need to coat these with anything special prior to finish painting?
Thanks
Bytor,
It’s possible some silicone or mold release agent may be reacting with the resin, or possibly the proportions of par A and B might be off.
I’ve found I have fewer problems if I follow these guidelines:
  1. Make sure you carefully mix the correct proportions of resin part A and part B. I use 3ml syringes.
  2. Ensure you completely mix the two parts before you fill the mold. I use cut-down film canisters and stir with a flat stirrer.
  3. Soak the parts in a strong detergent before you use them (some people recommend a bleach used for white wall tires).
  4. Use an automotive acrylic primer for the resin.
  5. Wait at least a 2-3 days before using the part to allow the resin to completely cure - I don’t know if this really makes a difference, but I’ve found that the resin bits seem “dryer” if they’ve sat for a week.
    Good luck.
