Resin cockpit interiors
Trying to find resin cockpit interiors (front and back ) for Academy’s T-33A 1/48 scale. I was a flight line mechanic on these during the Korean war, if I can’t find them will have to go with whats in the kit.
Thanks,
CPO ( Pat )
pobrient@compascable.net[:)]
Eduard has a great PE set for them, the resin set I have/had for mine was a total disappointment can’t remember who’s it was. The PE and doing a little scratchbuilding and spares raiding will yield your best bet IMHO.
Chief, Verlinden did a T-33 cockpit set that i think is for the Academy kit.
http://www.greatmodels.com/~smartcart/cgi/display.cgi?item_num=VPI0854
Thanks for the info, this has been a hard item to find.
CPO
Thanks Rob, I haven’t checked Verlinden as yet.
CPO
True Details makes the ejection seats in a pair. There are also some old brass PE from Reheat still to be found for this kit if you are willing to work with that instead of resin.
Stikpusher…thanks for the info, I have never worked with brass and as far as that goes I have never worked with resin either.Will check with Reheat.
Thanks again,
CPO
From the foothills of the Blue Ridge Mountains. [:)]
