Replace landing light
I’m in the very final stages of a 1/48 Tamiya Mustang III build (started 2007). I put in the landing light too early in the build and it disappeared somewhere in the wing. No rattle, no sign of it, and do not want to take the wing apart.
I’ve had a ton of ideas on how to replace it…make a backing with a) bare metal b) putty, then a) carve clear sprue, b) try to make a cast with future…that’s four approaches right there, plus whatever I’m too dense to think of.
Any suggestions?
Thanks!
Clear epoxy makes great lenses, especially if its a round lens that you need. You just have to make sure to keep the new lens level until the epoxy cures. It will have a natural tendency to form a convex shape.
Eagle, would you recommend standing it on its nose or on its tail to accomplish that?
I’m looking at the same issue with the Hustler; no nose gear lens at all, just the housing with a flat face.
Hi;
Any lights on an aircraft I always do from Clear scrap Sprue. That way I can get the general shape Before installing the lens.
In the case of the landing light, I would recommend standing it on its tail so that the light housing is level. Gravity and time will do the rest of the work while the epoxy cures, just have to make sure the light housing is perfectly level so the epoxy settles around the center of the lens it is forming. You can also get red, blue, and green dyes made specifically for epoxy to make colored lenses.
