I have an old model of the Constitution that my father built. The bow sprit broke before and I glued it back. I don’t recall if I used plastic cement or super glue. It was brokeN again during our last move. How can I fix this again and make it more sturdy?
You will want to locate some fine brass or steel wire. Copper or solder will be too soft & flexible. Also find a matching drill bit.
Drill into each side of the broken piece & insert the wire stiffener. Glue with CA You want the holes to ideally be about 0.25 inches in depth
Hint drill one piece Insert a length of wire slightly longer than the hole depth - or use a pin cut to length Bring the pieces together and align Press the wire/pin into the undrilled piece to mark the location to drill the second hole
Thanks. I drilled the holes. And used a small paper clip and glue to mend the two sections. This model is about 24in. Not sure of the scale. It isn’t the 1:96 nor 1:146 Revell Kits.
But with the bowsprit repaired, I can glue on some other small pieces. The. Begin re-rigging the ship. The old rigging was covered in dust.
Take a photo you may have of her Before the injury . Then do this from the first Fore-Stay back , put a number flag on each piece of rigging . Then remove the stub .Go to a kitchen supply store and purchase a set of medium skewers . They are Beechwood I think . Cut one to size , sand to a taper first , then install .
Before you install it soak it in HOT Strong Coffee .That will tone it close to the color it should be .By numbering the Forestays etc. you’ll know what goes where. Install and enjoy her for more years . Tanker - Builder
It sounds like your Dad built the Revell “Simplified Build” Constitution kit. It was 22" OA with a 17" hull. It scales at about 1/159.
The other possibility is the IMAI or Monogram kit listed as 1/120 and is 29"OA with a 19 inch hull.
In either case they are both great kits.
Can you post some photos of the model? I would really like to see pictures of your Constitution.
Since you recently joined and have probably not posted any pictures yet, there is a bit of a learning curve to post pictures. The Technical Assistance Forum and also the Testing Forum have some photo posting information. However, the best resource is Just Ask.
