Hi all. I read somewere that someone used Oven Cleaner to remove paint from a model. I am using Acryl Paints and wanted to know the best way to get it off some parts of my model
Thanks all
Bud
Thanks all
Bud
http://www.finescale.com/FSM/CS/forums/632707/ShowPost.aspx Read that, Windex works pretty good.[8D]
Thanks, I am going to try that right now. Will let you know how it works out
Bud
Windex is fantastic (make sure it’s the kind with amonia in it) for disolving acrylics. [tup]
I tryed the Windex and some came off but not all. I am going to let it soke in it and ues a toothbrush on it latter
Thanks
Bud
Testors does make a Dried Acryl Paint remover: http://www.testors.com/catalog_item.asp?itemNbr=1166\
Jesse
Try Simple Green, you can get it a decent hardware store. Works greart for removing Acryls.
Thanks all
Bud
Formula 409 takes dried acrylic off - if its a little stubborn, soak a piece of paper towel, and lay that over the spot you want to strip.
I keep a bottle for models. You can pour it into a container, soak the model, and then pour it back into the bottle. You can make one bottle of 409 last a long time that way.
